HeadlightArmor
Old 03-19-2013, 07:09 AM   #1
TSSUNAMI
It was ninety nine cents!
TSSUNAMI's Avatar
Drives: 2014 Jeep Wrangler
Replacing AC belt. Use GM or Gates?
Hello,
I have had to replace my AC belt going on twice now. (The smaller belt on the crank pulley closest to the engine that runs the AC compressor)
Should I spend half the day at the dealership and get it done under warranty? Or just bite the bullet, and spend 40 bucks for the Gates belt, which is supposedly more durable and less prone to breaking.
http://www.jscspeed.com/catalog/Gate...S-16068-1.html
^^ link to the belt manufacturer's website ^^
Anyone have any experience with this product?
Should I be concerned that I have a bad compressor bearing? Or that something is out of whack on one of my pulleys?
TSSUNAMI is offline   Reply With Quote
Old 03-19-2013, 08:11 AM   #2
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
I couldn't find a Stretch belt local so I just used the standard Gates belt and had no problems. And my car sees 7000 rpm a lot.. If you've lost 2 belts now, I would say something is wrong.
Nitroman28 is offline   Reply With Quote
Old 03-19-2013, 08:26 AM   #3
Alvin@PCMofNC
Drives: 2010 IOM RSS
I agree you must have a problem somewhere. does the main belt also look like its starting to get chewed up? I might would do it under warranty just so they have records of it if something truly is bad.
Alvin@PCMofNC is offline   Reply With Quote
Old 03-19-2013, 08:38 AM   #4
el ess A
formerly "el ess X"
el ess A's Avatar
Drives: 2010 & 2013 Camaros
I agree, let the warranty deal with it if it's a manufacturing defect. That's why you pay for it. If it's chewing belts, it'll eat anything you buy for it.
But if you're hell bent on buying one of your own, Gates is a supplier for GM and makes a lot of belts for them. So I don't think you could go wrong using a Gates belt. I'd shop around if you want to buy the belt yourself. You can get that same part number belt from Amazon.com for $33 and change shipped to your door. Why pay more for the same part?
2010/2013 Camaro
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 03-19-2013, 10:10 AM   #5
TSSUNAMI
TSSUNAMI's Avatar
Thanks for the advice guys. I will have them check it out at the dealership to make sure there's no major problem.
My belts aren't splitting or chewed. The accessory belt just keeps riding up off of the crank pulley. The other belt is fine.
I'll keep Yas posted.
Old 03-19-2013, 10:16 AM   #6
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
That sounds like an alignment problem between the 2 pulleys.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 03-19-2013, 02:39 PM   #7
gml1998
gml1998's Avatar
Drives: 2010 Synergy Green Camaro
I think there is a TSB for this situation.
gml1998 is offline   Reply With Quote
Old 03-25-2013, 12:11 AM   #8
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
there is a tsb for the crank pully,perhaps worth looking into also if you do it yourself make sure you have the special tool for stretching the belt.good luck!
firestone_ss is offline   Reply With Quote
Old 03-25-2013, 07:46 AM   #9
BOSS_HOSS
BOSS_HOSS's Avatar
Gates makes the OEM belt for GM.
2010 2SS/RS 1 7/8" Long Tube American Racing Headers w/high flow cats, Borla S-Type Catback Exhaust, Roto-Fab CAI, VMAX Ported Throttle Body, MGW Shifter, JRE 445 Street Cam Package tuned via SCT, Pedders Street 1 Kit.
BOSS_HOSS is offline   Reply With Quote
Old 03-25-2013, 10:03 AM   #10
2011 SS SLP ZL427
2011 SS SLP ZL427's Avatar
Drives: 2011 SS ZL427
It doesn't matter what belt you install on the Accessory drive you need to address the alignment problem between the two pulleys so that whatever belt you install stays lined up and on the crank pulley, the OEM belt will be fine once you correct the underlieing problem thats there.
2011 SS SLP ZL427 is offline   Reply With Quote
Old 03-25-2013, 04:55 PM   #11
Oldag
Drives: 2013 2SS Convertible, LS3
If you have a choice, go with Gates manufactured belts. I have never had a Gates fail.
Oldag is offline   Reply With Quote
Old 03-26-2013, 11:49 AM   #12
TSSUNAMI
TSSUNAMI's Avatar
Just got back from the service department. Everything was lined up as it should be, somehow the belt just slipped. They replaced the belt under warranty. Sound is gone for now. Let's see how it holds up.
Old 03-30-2013, 08:19 PM   #13
rontammy0
Dr feelgood
rontammy0's Avatar
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Originally Posted by TSSUNAMI View Post
Hello,
i had my replaced by the dealer..the belt was split..there is a few posts on here with this problem.....the thinking is that the compressor face where it bolts up is not machined square so it doesnt align right with the crank pully..the dealer may replace the compresssor for you
K@N Typhoon Cai
Vmax Ported Throttlebody
MSD Super Conducter plug wires
JBA shorty headers
Solo high flow cats
391 gears
Cosra Exreme 3 inch catback exhaust.
Circle D 3200 stall converter
305 x 35 20 Nitto 555r drag radials
AGP Performance tuned
rontammy0 is offline   Reply With Quote
Old 03-30-2013, 09:29 PM   #14
DCC1464
COTW 5/27/13
DCC1464's Avatar
Drives: '11 S/C SS/RS CGM
I've thrown three ac belts now and was told those were just defective belts......... we will see how long this one last. Hope yoh don't have this issues it is just stupid that they (gm) don't really care to find the underlying issue
622RWHP/512FTLBS on 91 octane
2.9l Whipple 4" pulley. Vengance VRSP3 cam. Lots of BMR & AAC. Body work by Gary's Customz. Nic D tuned
My build thread
DCC1464 is offline   Reply With Quote
