BeckyD @ James Martin Chevy
Old 03-19-2013, 03:02 PM   #1
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
IPF Self-Installs, Note To Consider
Make sure your braided steel oil drain line is rounted AWAY from the aluminum air conditioning line that's directly below the supercharger.
It's an expensive lesson.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 03-19-2013, 05:03 PM   #2
KMPrenger
KMPrenger's Avatar
What happened?
Old 03-20-2013, 01:32 AM   #3
FNG
Tampa Bay Camaros
FNG's Avatar
Drives: Rally Yellow 2012 ZL1
Originally Posted by KMPrenger View Post
What happened?
THIS ^
FNG is offline   Reply With Quote
Old 03-20-2013, 01:42 AM   #4
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
Steel won over the aluminum hu? Those aluminum hoses are expensive. Thanks for the tip, I'm sure people here will take note of that.
christianmotox is offline   Reply With Quote
Old 03-20-2013, 01:43 AM   #5
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
are these really easy enough that people with some experience can do it themselves?
nikos30 is offline   Reply With Quote
Old 03-20-2013, 01:50 AM   #6
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Yea, if you pm me your email, I think I can send you the install manual so you can see it if you'd like
Old 03-20-2013, 01:55 AM   #7
nikos30
HT5 EastSide
nikos30's Avatar
I have like zero dollars so...Id like to see it anyway.
Old 03-20-2013, 08:46 AM   #8
JohnnyBfromPeoria
The loose hanging drain line for the supercharger, provided for when its oil needs to be changed, is coated in braided steel. I neglected to take into consideration that it might rub against something, which it did. In this case, it pretty much sawed its way through an aluminum air conditioning line that was right below it. I had to order a new line and will have to have the system evacuated and recharged after a new line is installed.
And yes, a handy person can self-install the IPF s/c kit.
John B.
Old 03-20-2013, 09:46 AM   #9
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Dang that stinks, sorry to hear that happened.
Sent from my SAMSUNG Galaxy S III using telekinesis.
BaylorCamaro is offline   Reply With Quote
Old 03-20-2013, 10:31 AM   #10
Nutbutt
Nutbutt's Avatar
Drives: 2011 RJT 2LT/RS Convertible
My drain line has a sleeve over the braided drain hose. I positioned this and wire wrapped it so it didn't touch anything.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
Nutbutt is offline   Reply With Quote
Old 03-20-2013, 03:39 PM   #11
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
This is the same braided oil drain line that comes on every Vortech V3 self-contained unit, we usually adel clamp or zip tie it off to the side. Never used a sleeve before on any of them.
Matt @ FSP is offline   Reply With Quote
Old 03-20-2013, 04:01 PM   #12
nikos30
HT5 EastSide
nikos30's Avatar
Matt knows nothing about cars, dont listen to him!
Old 03-20-2013, 04:32 PM   #13
Matt @ FSP
Matt @ FSP's Avatar
My internet feelings were hurt by this big E-Thug bully :(
Old 03-20-2013, 09:00 PM   #14
Vader2011v6
Vader2011v6's Avatar
Drives: 2014 custom blue ZL1
I actually ended up bending the ac line a little to get it away from the hose. My friend and I figured that would be a problem in the near future. I did a self install with a good buddy of mine. Supercharger installs can be done but may need to be prepared for a few things.I actually will post a thread with all kinds of pics. Took pics of every step.
Custom blue 2014 ZL1. Cold air intake,clear bra,apex springs,apex oil catchcan,18 percent pulley,stainless works long tubes wit high flow cats,ls3 throttle body, (595tq/607hp) to the wheels
Last edited by Vader2011v6; 03-20-2013 at 09:03 PM. Reason: Accidentally hit submit when I was still writing rest of post
Vader2011v6 is offline   Reply With Quote
