BORLA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic
Old 03-20-2013, 12:50 PM   #15
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Yes, got the Hotchkis 1" for my convertible. Got them after seeing how incredible pics of lowered cars look on this site. and now in person I can say it is even better, wow. The car looks half the size now.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 03-20-2013, 01:02 PM   #16
PonyKiller74
PonyKiller74's Avatar
Drives: 2012 Triple Black ZL1 M6
Send a message via AIM to PonyKiller74 Send a message via Yahoo to PonyKiller74
Went with Pfadt ZL-Spec Sway Bars and Springs, Awesome look and ride. Apex Motorsports
CenterForce DYAD Dual Disc Clutch, JDP stage 2 Clutch Reservoir, Rotofab CF CAI with Big Gulp and WW Reservoir Relocate, Stainess Works LT Headers and Retro Cat-Back with Cat Delete, MGW ST Shifter with custom Knob, CF Tail light Bezels, more to come...
Build Thread for my Z is in the works.....
PonyKiller74 is offline   Reply With Quote
Old 03-20-2013, 11:10 PM   #17
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Go with 1" drop to have a firmer, but softer ride. I am slammed at 1.5" inches. I would love to trade for 1". I will soon I am sure. Most likely, coilovers.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 03-21-2013, 03:00 PM   #18
IrocJack
IrocJack's Avatar
Drives: 2010 2LT/RS RJT
Wow, this is alot of great info. I really appreciate everyone's input. Did everyone have to get that timing done on your bushings along with an alignment? did anyone not do the timing and if so any issues?
Thanks again.
IrocJack is offline   Reply With Quote
Old 03-21-2013, 09:43 PM   #19
edog
edog's Avatar
Street 1 bushings installed. No issues before installed.
Old 03-21-2013, 10:01 PM   #20
mntgome1
mntgome1's Avatar
Drives: 2012 AGM 2SS/RS
Lowered on Eibach pro kit. I have heard great things about all kits. This is my first time lowering a car and I like it. No issues to date.
mntgome1 is offline   Reply With Quote
Old 03-21-2013, 10:24 PM   #21
Tribute
Tribute's Avatar
Drives: 2012 SLP ZL770 #17 (Hugger Orange)
I'm running eibach coil overs. I've been very pleased with them.
My Build Journal
Tribute is offline   Reply With Quote
Old 03-22-2013, 10:08 AM   #22
IrocJack
IrocJack's Avatar
Will Pfadt springs off a V8 work on a V6?
Old 03-22-2013, 02:21 PM   #23
CruznSS
CruznSS's Avatar
Drives: 2SS/RS Camaro ABM - Silver Ralleys
Installed Hotchkis Stage III kit. Dropped 1". Handles 100% better in corners without the body roll like stock. But the kit added sway bars, strut and sub-frame brace which all contributed to stability. I agree you have to be more aware of road conditions being lowered but wouldn't go back due to how much more fun track time is....
CruznSS is offline   Reply With Quote
Old 03-25-2013, 04:36 AM   #24
IrocJack
IrocJack's Avatar
Thank you for all this info.
Old 03-25-2013, 06:27 PM   #25
Synner
Drives: not stock
Thanks again.
I did coilovers so not everything applies directly but... I installed them myself and had the alignment shop time the bushings when it was on the rack. I drove it a few hundred miles to let the springs settle before the alignment. Whether it was the springs breaking in and the preload settling out or the timing of the bushings but the car had some bounce before it was timed and aligned. Others have reported similar results, bounce went away after timing. Since springs don't have adjustable preload then I can only assume the timing of the bushings helped others as it helped me. The more you take the car away from its original height the more you'll have negative side effects if you don't time them.
I would also second doing no more than a 1" drop. Anything else and ride quality suffers along with shock longevity. Unless you only want to stare at your car in a parking lot you won't be happy for long. Or do coilovers and drop as low as you want within reason to not scrape hard parts. I'm only dropped 1" on the coilovers but I did it for road course performance/adjustability primarily. The spring swap itself was actually very easy, didn't even require a spring compressor.
Old 03-25-2013, 06:37 PM   #26
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
We recommend Hotchkis springs for a 1" drop and Pfadt for 1.25" Both springs are great.
Yes. Pfadt redesigned the springs to work on both the V6 and V8 models.
Please feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 03-25-2013, 06:48 PM   #27
Synner
Drives: not stock
..one more thing. In regards to cutting bump stops, I will NEVER run a spring that requires a bump stop to be cut. It's there for 2 reasons.
1) Stopping hard parts from hitting/shock bottoming out
2) Keeping the shock within its correct operating range
Trimming it shouldn't be an issue for #1, but taking a shock out of its operating range is why they die incredibly fast and performance suffers terribly as well. I don't care what any manufacturer says, its not ok in my book to trim a bump stop. My 2 cents, take it for what its worth.
Old 03-25-2013, 06:50 PM   #28
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
lowered mine :P
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
