Old 03-19-2013, 10:50 PM   #1
HOWFAST
HOWFAST's Avatar
Drives: 2015 Z/28
5TH and 6TH Gear Swap
I want to change 5th and 6th gears in my 1LE to ZL1 specification. Looking for a good transmission shop to do the work. I live Montana. Any recommendations will be helpful.
HOWFAST is offline   Reply With Quote
Old 03-19-2013, 11:45 PM   #2
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
What would be the purpose for this swap? What are you trying to accomplish?
1le gear ratios 2.66:1, 1.78:1, 1.30:1, 1.00:1, 0.74:1, 0.50:1 final drive 3.91
zl1 gear ratios 2.66:1. 1.78:1, 1.30:1, 1.00:1, 0.80:1, 0.63:1 final drive 3.73
tramtwo is offline   Reply With Quote
Old 03-19-2013, 11:47 PM   #3
b20
Drives: 2013 1LE RS 1SS
I USE D&D PERFORMANCE
THEY ARE IN DETROIT AND DO GREAT WORK CHEAP TO
b20 is offline   Reply With Quote
Old 03-19-2013, 11:56 PM   #4
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
C'mon man, the guy said he lives in Montana(as in the state).
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 03-20-2013, 12:04 AM   #5
b20
I SHIP THEM TO HIM ALL THE TIME
THEY ARE WORTH THE SHIPPING
Old 03-20-2013, 12:22 AM   #6
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
+1..
I dont think theres any need for that whatsoever. The 1LE has specific trans ratio very similar to the ZL1.
What are you planning to do with it? I guess you know what you are doing
TSP 231/236 111 cammed 1LE
WHAMMO is offline   Reply With Quote
Old 03-20-2013, 12:42 AM   #7
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
It would honestly be a lot cheaper to buy the ZL1 transmission and sell yours.
But like the others said, what are you getting to do this for?
Seems like a waste of money.
SUX2BU is offline   Reply With Quote
Old 03-20-2013, 09:32 AM   #8
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Originally Posted by WHAMMO View Post
+1..
If he is running an open road challenge or the Texas Mile it makes perfect sense....T
I'm gonna guess based on the OPs location this is for one of the following open road races:
http://www.sorcrace.com/
http://www.sscc.us/
-Matt
Old 03-20-2013, 10:16 AM   #9
HOWFAST
HOWFAST's Avatar
Drives: 2015 Z/28
b20- Thanks for the D&D Performance Tip.
Drop speed- You got the right answer.
Old 03-20-2013, 10:51 AM   #10
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
http://www.sscc.us/
-Matt
Makes perfect sense in what way? What is the advantage.... to have 5th and 6th pull harder?
tramtwo posted this on the go
Old 03-20-2013, 11:55 AM   #11
Dropspeed
Dropspeed's Avatar
Essentially yes, the OP is the only one that can answer his exact needs/purpose for doing so but in stock trim 5th and 6th are overdrive gears to keep the EPA happy/ increase MPG. With the car limited to 155 it makes no difference in top speed. With the limiter removed the car will run out of HP before gearing.
I assume that the limiter is removed and this will be used to achieve terminal velocity at a quicker rate!
EDIT:...It can also prevent a car from falling out of its power band with a shift from 4th-5th gear
-Matt
Old 03-20-2013, 01:08 PM   #12
tramtwo
tramtwo's Avatar
Drives: 2013 1LE
-Matt
Thanks.
Old 03-21-2013, 02:46 AM   #13
Bad@ssCamaro
Rogers' Rocks :-)
You guys scared him away...
Old 03-21-2013, 12:48 PM   #14
1BadAction
Because: Street Car!!!
1BadAction's Avatar
Drives: 2013 SS 1LE
Sounds like the easier way to do this would be to drop to a 3.23 rear gear and use 1-5... This would also keep the driveshaft turning at a more reasonable RPM.
Does anyone actually use 6th for top end runs?
2013 1SS/1LE Blue Ray Metallic Camaro - DD
1991 2500 Suburban - Roller cam'd high compression 454ci BBC tow monster -the build-
1979 16' Action Marine - Merc Racing 2.5XS
1BadAction is offline   Reply With Quote
