Old 03-20-2013, 12:21 PM   #1
ace32x
ace32x's Avatar
Drives: 2013 ZL1
upper and lower pulley's and blower life.
Collecting parts currently to throw on the car here shortly. currently have a custom ground cam a 9.1 lower crank pulley, 2.5 upper, solid isolator coupler, some kooks LT's and a kdi heat exchanger and a nick williams 102 TB that will go on when i port the snout.
what im curious about is blower life in the 1900 with the 9.1 lower and the 2.5 upper. im debating porting the heads and doing valves before everything gets put in and as that would lower the boost some since theres less restriction would bumping up the 9.5 lower and having the 2.5 upper significantly increase bearing wear on the blower vs the 9.1 and 2.5 combo?
and what are we seeing failure points on the bottom end of these things stock? i havent heard of one failing yet so im curious
(will be tuning on 92)
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
ace32x is offline   Reply With Quote
Old 03-20-2013, 12:57 PM   #2
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
How do you like your KDI H/X? Have you monitored IAT2's and seen a difference?
69NMYSS is offline   Reply With Quote
Old 03-20-2013, 01:05 PM   #3
ace32x
ace32x's Avatar
Drives: 2013 ZL1
i havent put any of it on yet still compiling parts haha. just has the lower 7% pulley on it atm and the rotofab intake. the cam headers heat exchanger tb and coolant pump and upper pulley are just sitting on my pooltable eating up space.
Old 03-20-2013, 10:10 PM   #4
Azzkker
Azzkker's Avatar
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z
where did you buy your coolant pump from?
Azzkker is offline   Reply With Quote
Old 03-20-2013, 10:52 PM   #5
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I don't know if I have seen anything other that recomended RPM range for the blower and I don't know how much life is decresed if you go over it.
I am not sure you are factoring in the blower RPM in the equation. both the combo's you posed in are over the recomended blower RPM.
I think you are looking at 23,400 vs 25,500 rpm on those two combo's.
I would rather run the 2.55 and the 8.6 and have a little more rpm out of the motor.
port the heads in my mind if your going this far.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 04-10-2013, 11:03 AM   #6
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
Anything above 23,000 is not really suggested
Take a look at our belt selection guide and blower rpm sheet:
https://torq.zendesk.com/entries/235...election-Guide
Meister@Torq is offline   Reply With Quote
Old 04-10-2013, 11:16 AM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
chart is wrong...here is the right one. Look at 9.55" and 10" rpm column...how could they be the same? http://www.lingenfelter.com/sites/li....0%20small.pdf
page 7
'17 ZL1 A10 Mosaic Black PDR/Nav 2:07.59 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is online now   Reply With Quote
Old 04-10-2013, 04:17 PM   #8
Meister@Torq
Thanks. Should be fixed
Old 04-11-2013, 01:48 PM   #9
BLACK10
BLACK10's Avatar
We have many Zl1's using that combo you posted. you will also need to run aftermarket idler pulleys to prevent belt slippage.
Old 04-12-2013, 04:58 PM   #10
Mattzl1
Mattzl1's Avatar
Drives: 2013 ZL1
There is alot of ZL1's out there with the 2.5 and 9.1 combo and that is just over the recomended max RPM range. Lingenfelter used the 2.5 and 9.5 on the car they were making the 760HP and say they have been using that combo on the CTSV for a while. Lower boost from less restriction doesn't mean less power, it just means more efficient power.
2013 ZL1 AGM, ECF, A6, sunroof, black rims
mods complete! 664 RWHP, 645 RWTQ
Ported snout, 2.5 upper, Innovators west balancer with 9.1 lower, New era intake, American Racing long tube headers with hollow cats and X pipe, KDI heat exchanger, ID850's, TS29 cam !
Mattzl1 is offline   Reply With Quote
