Solo Performance
Old 03-20-2013, 09:03 PM   #1
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
Is This a Mistake? V6 A6 Tranny Only Rated for 315 hp?
So I was looking at the GM Powertrain web site, and looked at the A6 used in the V6 Camaro (select "transmissions," then select the 6-speed auto with code "MYB"), and under the listed specs, it says, "Maximum engine power: 315 bhp (235 kw)."
How can that be, when the '12 and up models make 323 hp? Or is it the bhp that makes the difference?
911medic is offline   Reply With Quote
Old 03-21-2013, 06:11 AM   #2
911medic
911medic's Avatar
Hmmm... Looking at the definition of bhp leads me to believe that if anything, the bhp figure could actually be higher than the standard hp measured at the crankshaft - or at least the same: "Brake horsepower (bhp) is the measure of an engine's horsepower before the loss in power caused by the gearbox, alternator, differential, water pump, and other auxiliary components such as power steering pump, muffled exhaust system, etc."
Which means the LFX engine exceeds the hp rating of the transmission it's paired with. And that's before mods.
I am confused...
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
Old 05-20-2013, 08:10 PM   #3
cjcamaro10
cjcamaro10's Avatar
Drives: 2010 LS 6M
I believe they are rated for right around stock hp, however it's usually not the hp that kills a Trans, it's torque and traction.
cjcamaro10 is offline   Reply With Quote
Old 05-20-2013, 08:32 PM   #4
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Lmao you should see what the M6 tranny in the 5.0's is rated for.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 05-20-2013, 09:17 PM   #5
Vroom_vroom
The gritos pollo!!!
Vroom_vroom's Avatar
Drives: Like a idiot
This is like a bad flash back to my gxp Grand Prix, you can destroy that thing with out trying or even modding for that fact.
______
If you don't stop how can they give you a ticket?-The Big Tuna___
'12 1Ls Camar
o; Slp loud mouth I|maganflow x-pipe|Injen long ram intake
|brembo brake upgrade| russell s.s. lines|2LT polished 19's|billet 5mm spacers|tinted tail lights&markers|pdmi|billet c. can|
'13 Avenger R/T
'77 T/A 6.6;, draining my wallet.
Vroom_vroom is offline   Reply With Quote
Old 05-20-2013, 09:28 PM   #6
911medic
911medic's Avatar
Since this thread generated no responses in almost 2 months, I reposted it here and there was further discussion, if you're interested: http://www.camaro5.com/forums/showthread.php?t=296243
Old 05-28-2013, 02:32 PM   #7
scites
Drives: 2010 camaro SS/RS
Heat is what will kill an auto tranny..
scites is offline   Reply With Quote
