ADM PERFORMANCE
Old 03-21-2013, 03:34 PM   #1
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
SOLO HF Cats
Anyone know for sure which of the Solo cats would work with the ZL1? The guy I contacted at Solo says he thinks the L99 cats should work the the A6 ZL1.
Any help would be appreciated ...
Old 03-22-2013, 12:21 AM   #2
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I have not seen anyone confirm fitment. I do know that the JBA midepips for the SS fit the ZL1.
The solo's in my mind are too much money. when I priced them they were like $550. you can get stainless power or texas speed o/r longtubes for $699 or so.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 03-22-2013, 08:16 AM   #3
SlingShot
SlingShot's Avatar
Thanks, I was looking for something that would bolt up to the stock manifolds. I'm trying to avoid any tuning at this time.
Old 03-22-2013, 09:53 AM   #4
AMCBimmer
Drives: 2002 BMW M5
I am going with Kooks 1 7/8 and Kooks Green Cats. No tune is required on this and many of the SS guys have had no CEL come on because you are keeping your O2 sensors in place. I am going to do a stock dyno then a dyno with the headers and cats with stock exhaust here in the next few weeks. I am NOT going to tune.
AMCBimmer is offline   Reply With Quote
Old 03-22-2013, 09:55 AM   #5
SlingShot
SlingShot's Avatar
Cool, please post your results ... looking forward to what you find out.
Old 03-23-2013, 07:56 PM   #6
ZL1#216
Drives: 2012 ZL1, 1996 Z28
I also am looking for exhaust "no tune" options. Has anyone installed the solo cats on a ZL1? If so what are the hp and sound improvements.?
I'm also interested in the Kooks headers when green cats option. I saw on another thread a comment that this option might cause the engine to run lean with the factory tune at WOT. If true, this option would not work for me since I attend open track days quite often.
I appreciate any information or insight anyone might have on either of these options.
ZL1#216 is offline   Reply With Quote
Old 03-23-2013, 08:20 PM   #7
AMCBimmer
Drives: 2002 BMW M5
I don't understand how the car would run lean. The MAF should be able to compensate for these changes.
Old 03-23-2013, 11:00 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I have seen no tuner recomend longtubes without tune. the location of your front o2's change and usually the car can't compensate.
you couple in other mods like cai or other things it will get worse.
if you really want a no tune option I would try the JBA catted midepipe. if you did get a CEL it would be a rear 02 CEL and there are work arounds for that.
I have seen one member say he was running longtubes no tune and then about two days later he said he had to tune.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 03-24-2013, 09:05 AM   #9
ZL1#216
You make a good point about the primary O2 sensors.
Old 03-24-2013, 06:26 PM   #10
AMCBimmer
Drives: 2002 BMW M5
ZL1 with green cats and Kooks LT
http://www.gmhightechperformance.com.../photo_18.html
Old 03-24-2013, 07:26 PM   #11
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
The green cats are way too expensive. If you're making 650rwhp+ get cheap cats because you're gonna keep blowing them out anyway. Paying $1500 once a year for cats isn't economically wise when you can pick up a set of cheap cats for $250. If you're under 650rwhp and just like to spend money then buy them.
RoketRdr is offline   Reply With Quote
Old 03-24-2013, 08:10 PM   #12
AMCBimmer
Drives: 2002 BMW M5
The only reason I want the green cats and long tubes is because I'm not going to modify the car to the extreme. Why would these cats blow out? The same thing should happen to oem cats if this is true?
Old 03-24-2013, 10:57 PM   #13
RoketRdr
RoketRdr's Avatar
All cats will blow out. When you start making 650rwhp+ you will eventually blow the cats. This is why almost everyone running this power level or higher gets rid of the cats. What happens is they begin melting and the guts end up giving way. They can even plug off and cause engine damage.
Old 03-25-2013, 02:40 PM   #14
AMCBimmer
Drives: 2002 BMW M5
So you are saying green cats and headers are going to blow out even keeping the car stock with no tune. I'm only doing headers, rotofab intake, and kooks green cats.
