Old 03-21-2013, 06:28 PM   #1
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
zl1 nitrous kit
Looking for Nitrous kit for my ZL1. Anybody seen any available?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 03-21-2013, 06:31 PM   #2
KKreme15
KKreme15's Avatar
Drives: C6 Z06
http://www.camaro5.com/forums/showth...ect+port+spray
KKreme15 is offline   Reply With Quote
Old 03-21-2013, 06:39 PM   #3
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Dang I just found that too...thanks.
2012 ZL1
Old 03-21-2013, 07:08 PM   #4
12 ZL1 #1725
12 ZL1 #1725's Avatar
Drives: 2012 ZL1 Black 6M
Nice!!
Sit Back and Enjoy The Ride!!
12 ZL1 #1725 is offline   Reply With Quote
Old 03-21-2013, 07:54 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
you can use a basic LS1 kit with a "shark" nozzle (n20/fuel) with 100hp or 150hp pills to wake up the LSA. It is very easy to install and an extravagant system like above is not necessary unless you want to get really serious. Here is a pic of a nozzle that can be simply plumbed into the air intake.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 03-21-2013, 07:55 PM   #6
Stephen12ZL1
Drives: '17 ZL1 A10
pic
Old 03-21-2013, 07:58 PM   #7
Stephen12ZL1
Drives: '17 ZL1 A10
Made my 4600lb Mercedes go from 11.25@122 to 10.58@132
http://m.youtube.com/watch?feature=plcp&v=dIG-akdyAiM
Old 03-27-2013, 11:50 AM   #8
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Bump
Old 03-28-2013, 06:14 PM   #9
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
cool. Inexpensive, and cools the rotors too.
2012 ZL1
Old 03-29-2013, 01:19 PM   #10
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
does the ecu need tuned to run nos ?
CAM....ZL1 is offline   Reply With Quote
Old 03-29-2013, 01:27 PM   #11
MIKE@TF
Drives: Srt8 jeep,02 mustang gt,2009 ctsv
yes..you need to pull timing..how much is dependent on how big of a shot.
MIKE@TF is offline   Reply With Quote
Old 03-30-2013, 09:56 PM   #12
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
Really? I was under the impression that those nozzles were flow matched for proper mixture so long as fuel and bottle pressures were within specs.
LuckyZL-1 is offline   Reply With Quote
Old 03-30-2013, 10:20 PM   #13
Stephen12ZL1
Drives: '17 ZL1 A10
most tuners definitely rx pulling some timing when spraying n20. Small shot of 75hp is probably no big deal. 100hp and up may be a problem without retarding the timing a few degrees.
Old 04-02-2013, 04:08 PM   #14
zl1fun
Drives: 2013 ZL1 # 1029 black
So what parts would be necessary to acheive this inexpensive nitrous set up? I can't seem to find any info on such a basic set up. It sounds like a good idea but I don't know anything about it. can an amateur install it properly?
zl1fun is offline   Reply With Quote
