B&M Racing
Old 03-22-2013, 09:03 PM   #1
JCar23
Drives: 2010 Camaro 2SS RJT
Itsx tuner
I'm getting ready for spring thaw and getting my car out too and bought SCT ITSX tuner from Jannettyracing.
Yesterday I paired it with my ipad and saved my stock tune and e-mailed to Ted last night. Worked great. Ted got my custom tune back to me this morning, so this afternoon I attempted to load it. I downloaded the tune to my ipad, saved it the app. But when I went out to load it on my Camaro, I plugged the tuner into my OBDII port but my Ipad couldn't connect to the device. Ted had my forget the device on my ipad and try to pair it again but no luck there. When I plug the tuner into the port, the tuner doesn't even light up, as if it doesn't have any power.
So I decided to disconnect everything and start up my car to make sure it still ran... it did. But I noticed the OBD indicator light stayed on.. I'm hoping a fuse is blown causing no power to power the tuner from the OBD port and causing the light to stay on. I looked at the fuses in interior of the car but they appeared to be fine. I read there is a box in the trunk and under the hood. Before I try to get to the ones in the trunk, anyone else have this problem? Sent a message to Ted too, but maybe he will read this over the weekend to give me a tip. Or I can call SCT also. And I'll do some more searching on the web.
Thanks!
JCar23 is offline   Reply With Quote
