Old 03-23-2013, 07:10 PM   #1
NYYFan325
Drives: 2010 Camaro 2SS/RS
What can I tune on my stock LS3?
So my friend has an HP tuner and he is flying out here from NY (to Vegas) for my b-day. Aside from removing my skip shift, I was wondering if there is anything else he could/should do while using the HP tuner on my car?
I realize being stock I don't have much to gain, but any little bit helps right? Thanks for any info!
NYYFan325 is offline   Reply With Quote
Old 03-23-2013, 08:44 PM   #2
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
He can remove the torque management, maybe bump the timing tables (make Lo & Hi octane the same) if you are going to run 93 all the time to keep from losing advance in a KR learn down. Increase the rate the PE richens up at WOT and lean it out some but you need a wideband O2 installed before I'd mess with the fueling. Too lean will cause issues long term.
Launch control can be lowered to something reasonable like 3k rpm and you can set up the no lift shift like the 'vette if you want.
Lots of possibilities since you are going to blow your warranty anyway for just the CAGS defeat. If you have an intake now is the time to tune for it also.
If all I was going to do was CAGS, I'd buy the cable for $30 instead and keep the warranty.
Iam Broke is offline   Reply With Quote
Old 03-24-2013, 01:08 AM   #3
NYYFan325
Car is a 2010 with 55K on her... isn't the warranty is over anyway? Thanks for the info!
Old 03-24-2013, 10:05 AM   #4
Iam Broke
PHAT B33
Iam Broke's Avatar
I think you have a 100k mile powertrain warranty. Not sure about the 2010's. Have fun.
Old 03-24-2013, 10:37 AM   #5
nele22
nele22's Avatar
Drives: 2012 SS
Correct. 5yr or 100,000 power train.
nele22 is offline   Reply With Quote
Old 04-02-2013, 04:18 PM   #6
QUICKSS
Drives: 2013 2SS
I never heard of this
QUICKSS is offline   Reply With Quote
Old 04-02-2013, 06:01 PM   #7
Iam Broke
PHAT B33
Iam Broke's Avatar
Join the HPTuners forums and read a lot.
Had it on my Cobalt SS turbo stock also.
Old 04-02-2013, 10:35 PM   #8
moserbe
moserbe's Avatar
Drives: 2012 Camaro SS
The OP indicated that he had the LS3 engine so it would have the manual transmission. Isn't torque management only applicable to the automatic trans?
moserbe is offline   Reply With Quote
Old 04-02-2013, 10:41 PM   #9
The Stig
knows 2 facts about ducks
The Stig's Avatar
Correct.
Click to view my build thread
Old 04-03-2013, 02:11 AM   #10
Rornls3
Drives: 2010 RJTC 2SS RS/SS LS3
What about increasing idle RPM? I hate that my LS3 isles at 600-800 or whatever. Just seems like the engine is starving or would be healthier with a higher idle... Is it just me?
Rornls3 is offline   Reply With Quote
Old 04-03-2013, 05:40 AM   #11
Iam Broke
PHAT B33
Iam Broke's Avatar
There are torque management tables in play on the LS3 also.
Old 04-03-2013, 05:41 AM   #12
Iam Broke
PHAT B33
Iam Broke's Avatar
You can alter the idle tables as well.
Old 04-03-2013, 06:34 AM   #13
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
There are two Torque managements. One in the transmission on the automatic and one for the engine handled by the throttle body. That is why when you mash the gas it does not always just dump allot of fuel in 1st.
Sorry Stig
Scott@Bjorn3D is offline   Reply With Quote
Old 04-03-2013, 07:17 AM   #14
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Couple of incorrect statements in this thread, but if you friend knows how to use HP Tuners, he should be adjusting what's on my website in the street tuning package
www.TampaTuning.com
Or now would be a good time for you to pick up one of my Mail order tunes with HP Tuners
Tampa Tuning is offline   Reply With Quote
