Old 03-23-2013, 11:49 PM   #1
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
My 19x11 Forgeline square setup avec 315 Hoosiers
Weather has FINALLY improved enough for me to test out my Forgeline 19x11 GA3R shod with 315/30R19 Hoosier R6 slicks. Got these from Dave @ Forgeline direct . We went back and forth a bit before settling on the final front offset. I had as hard a time with the colour scheme, but everything has worked out perfectly.
Extremely pleased to report: "No fitment issues!!" Even going full crank backing out of and driving into my slightly elevated driveway (back lane) it did not rub turning left or right. The fronts protrude less than 1/2" beyond the top of the fender (see last 2 pics).
Lightly tossing it around reveals how well the Gen5 responds to a square setup. There is a whole lot of bite upfront now (even compared to my 285 R888s). Couldn't drive it hard cause it was night and currently 7°C (44.6°F) and the tires are like hockey pucks, eh?
Here are pics. Sorry, but ran out of light. Hope to get some day pics tomorrow.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 03-23-2013, 11:53 PM   #2
PLuche
PLuche's Avatar
Drives: 2012 Camaro 1LT manual
Looks different for sure. I feel like yellow lip and black spokes might have looked better but thats just my opinion
PLuche is offline   Reply With Quote
Old 03-24-2013, 12:41 AM   #3
bandier
Got mine!
bandier's Avatar
Drives: 2010 Camaro 2LT - Yellow w/ Stripes
what are you going to do with those things? got the Steam Roller look!
bandier is offline   Reply With Quote
Old 03-24-2013, 12:50 AM   #4
Avalnch
Avalnch's Avatar
That was my original plan, but I couldn't help but mix it up. It actually looks good in the light when you can distinguish the polished rim from the tire.
This is strictly for auto-cross use. The Hoosier tires are not street legal (even though they are DOT approved). I wanted to stuff the biggest tire I could up front for maximum grip and get rid of that pervasive oversteer that plagues our cars.
Old 03-24-2013, 01:10 AM   #5
grocerygetter
instigator
grocerygetter's Avatar
Lower...you have coil overs, make it so.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 03-24-2013, 09:12 AM   #6
Synner
Drives: not stock
Those will be fun. Did you check suspension travel to see if it would touch the front fender when compressed? Also you'll want to put a gravel guard or Zl1 style canard to protect the sides of your car, those will throw up tons of gravel onto the side of your car.
Old 03-24-2013, 12:17 PM   #7
SPCBA
Drives: pleather and Chiclets
its just his setup for track er autocross. hes not daily driving with these wheels and tires on
SPCBA is offline   Reply With Quote
Old 03-24-2013, 12:38 PM   #8
Rad_dsm
Rad_dsm's Avatar
Drives: 2011 synergy 2ss
Can you take some day time pictures? They look great. Thanks
Rad_dsm is offline   Reply With Quote
Old 03-24-2013, 12:47 PM   #9
Falundir
Falundir's Avatar
Drives: 2017 1SS 1LE - Hyper Blue, P85DL
Enjoy. I have a 19x10 square setup running 285/35 on all four and the cornering and steering precision is amazing.
Falundir is offline   Reply With Quote
Old 03-24-2013, 10:55 PM   #10
Avalnch
Avalnch's Avatar
Yes, I did check suspension travel and the smaller diameter tires will work to my advantage. I don't expect to rub there either.
You're right about the rock guards. With our soft paint job, I cringe when I think of the possible damage. I'm going to make a set myself. Extra wide and run them only when I have these tires on. These Hoosiers are like drag slicks after a burnout. They're super sticky and will pick up every grain of sand they run over.
Old 03-24-2013, 10:57 PM   #11
Avalnch
Avalnch's Avatar
Exactly. Besides, lower will make it possible to rub the top of the tire on the fender.
Old 03-24-2013, 10:58 PM   #12
Avalnch
Avalnch's Avatar
I'll try. Had a busy day today helping my sister move, so didn't get a chance to take it out in the day time.
Old 03-24-2013, 11:23 PM   #13
madmaxx18
madmaxx18's Avatar
Drives: 07_tundra/08_zo6
Are those Pfadt racing coilovers gen1 and what size springs the 8s?
madmaxx18 is offline   Reply With Quote
Old 03-24-2013, 11:28 PM   #14
Avalnch
Avalnch's Avatar
Yes, I've got Pfadt's gen1 coilovers with the shorter Eibach springs that you can get from them. The shorter springs are necessary to move the collars up and out of the way of the tire.
