Old 03-24-2013, 01:59 PM   #1
blackTT600
Drives: 2011 2LT M6 SC
LLT oil cooling??
what are our options?
Im thinking of getting a new oil filter adaptor http://www.google.com/imgres?imgurl=...ed=0CFIQrQMwEw
and then pluming in a universal oil cooler kit like this one http://www.amazon.com/Godspeed-Unive...im_sbs_auto_18
what has been done? what works? do yall think this is a good idea? if nothing else Ill have some nice AN fittings and bradded hoses in my engine compartment. lol
blackTT600 is offline   Reply With Quote
Old 03-25-2013, 10:23 AM   #2
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
I've been thinking about the same thing... but I've got several other things I need to do first. If you do this let us know how it goes.
Sent from my SAMSUNG Galaxy S III using telekinesis.
BaylorCamaro is offline   Reply With Quote
Old 04-05-2013, 03:19 PM   #3
Stratos
Drives: Corse Stratos
You would need a custom sandwich plate made as there is very little room between the block and air con pump. there is also incorporating the oil preasure gage at the filter - but feasible.
Stratos is offline   Reply With Quote
Old 04-05-2013, 03:23 PM   #4
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
heres mine also getting a transmission cooler next week will look about the same...
MARINE1991 is offline   Reply With Quote
Old 04-05-2013, 04:09 PM   #5
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Nice set-up. Be sure to check, but I thought our V6 already has a trans cooler built into the radiator. I will have to look that up again.
Old 04-05-2013, 04:29 PM   #6
Stratos
may be this from a LY7 would work - item 440
http://www.tonkinonlineparts.com/ima...31GM00-533.JPG
Old 04-05-2013, 08:48 PM   #7
blackTT600
hey man, that looks great how did you run the lines?
Old 04-05-2013, 08:50 PM   #8
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Are you guys seeing high oil temperatures?
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 04-05-2013, 09:06 PM   #9
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
If your running synthetic your good for up to the 300's in temps. But don't get fooled by the hype, these modern engines run best with the oil temps being high. Trans oil is a different sorry. I have never seen no more than 30* difference between my coolant and oil temps. And this is with turbo's in the Atlanta heat and dyno run with heat soak.
Can't_C_Me is offline   Reply With Quote
Old 04-06-2013, 09:29 AM   #10
blackTT600
I was at an auto cross and my oil temp was close to 260-270 I'm not ok with that. It was way on the high side of my gauge, not quite on the red but way high none the less. I'm in south east FL and its really hot already so yeah I do think this is necessary. Especially if I plan to do more events, which of course I will.
Old 04-08-2013, 09:43 AM   #11
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
I was thinking about getting one too since I plan to start auto-x'ing, but the runs are typically short enough to not worry about oil temps becoming a problem.
Either way I'd be curious to see what you come up with and what your findings are.
Please keep us updated!!
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 05-18-2013, 11:50 AM   #12
blackTT600
brought back from page 7... MARINE1991 you have a picture of the lines run, and installed? did you relocate the oil filter? where did you plum it to?
