Emblempros
Old 03-26-2013, 09:36 AM   #1
Bolt-onC6
Drives: 2017 Corvette
How about a 2008 Corvette?
2008 Crystal red, automatic, Z51, Dual Mode exhaust w/ext. commander, chrome factory wheels. Car has 14K miles. Comes with Kooks 1 7/8" headers with catted and off-road Kooks mid pipes, CAI, 3.15 ratio RPM differential (less than 1000 miles), Yank 3200 converter, UDP, Nitto Invo 19” rear tires along with Mickey Thompson drag radials out back on 18” wheels, M&H skinnies on GTO wheels with spacers, two narrowed chrome wheels with 205 tires that I use as semi skinnies up front. Total of 8 wheels and tires mounted on wheels and balanced. All tires plenty of thread left (most almost new). One set of Z51 rotors F/R and one set of base rotors F/R with two full sets of pads.
Car is excellent shape, not a scratch, everything works including cold AC, always garage kept, almost like new, original owner. Ran a best 10.88 @ 125.25 mph. Have all the original take off parts so it could be returned to stock. I have a maintenance record. Oil has been changed more than once a year. Always changed before the DIC due to so few miles per year. First oil change was at 1239 miles. Broke the car in 500 miles before going WOT. Most of the miles are freeway/highway. $35,000.Make offer. Email for more pics. 98larry@comcast.net
Bolt-onC6 is offline   Reply With Quote
Old 03-26-2013, 10:32 AM   #2
SC2150
Nice. How much did the Yank swap pick up in the 1/4 mile?
Old 03-26-2013, 11:04 AM   #3
Bolt-onC6
Can say for sure as I made some exhaust changes at the same time and not sure the air quality was the same but I went from an 11.32 to a 10.88 with the converter and a no cat mid pipe.
Old 03-26-2013, 11:15 AM   #4
Bolt-onC6
Here's the difference in time slips. The 10.888 was ran on January 21, 2012, 11.317 on January 14, 2011 if you want to go back and check the air difference on those nights. Not sure what the off road pipe did either. I had the high flow Kooks pipes on the car for the 11.317. Look at the difference in 60' times!
