Emblempros
Old 03-26-2013, 09:53 AM   #1
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
Code pulled from my car-- p015b & p015d
I'm a newbie at some of this but had these codes pulled from my car. I'm waiting for a tune next week. My mod list is 1-7/8 kooks headers with hi flo cats,adm scoop,CAI, dual mode exhaust. Headers went on a week ago and been babying it without a single WOT moment. From what I found, those codes mean lean to rich bank 1 & 2. Is my car in any kind of trouble?
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 03-26-2013, 10:03 AM   #2
less2010
less2010's Avatar
Drives: 2010 2ss camaro
If you get a tune,you will be fine.
less2010 is offline   Reply With Quote
Old 03-26-2013, 11:01 AM   #3
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Headers slow the O2 sensor response as they are farther downstream. Could be the cause. Your tuner will correct this.
Iam Broke is offline   Reply With Quote
Old 03-26-2013, 11:34 AM   #4
ROD_SS
ROD_SS's Avatar
That makes sense now. Just a little nervous, didn't want a 3k lb car as a paperweight for engine problems.
Old 03-26-2013, 05:14 PM   #5
Iam Broke
PHAT B33
Iam Broke's Avatar
I completely understand.
Old 03-26-2013, 07:43 PM   #6
Badman24
Badman24's Avatar
Drives: 2SS Black W/GFX
P0420 and p0430 are the ones for the rear o2 sensor after you put headers on and no tune
Badman24 is offline   Reply With Quote
Old 03-26-2013, 07:56 PM   #7
Iam Broke
PHAT B33
Iam Broke's Avatar
OP is referring to the front (control) O2 codes I believe. Not where I can look them up right now.
Old 03-02-2014, 05:47 PM   #8
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
I just installed headers and threw the same codes as the OP.
Hadn't heard of this one before so I guess the tune (coming next week) is needed.
Old 03-02-2014, 07:22 PM   #9
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Did you use extender harness on the front O2s ?
If you did, on the newer Camaros will throw that code because that extra foot of wire delays the reading.
Tampa Tuning is offline   Reply With Quote
Old 03-02-2014, 07:40 PM   #10
mlee
www.CamaroFest7.com
mlee's Avatar
I'll check that when I get it back in the air next week. I didn't do the install, but I thought the extenders were for the rear only.
Thanks for the help.
Old 03-06-2014, 02:40 PM   #11
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
The extenders are for the front. I just installed a set of Stainless power 1 7/8" headers and haven't gotten that code using the extenders they provide.
I got a P0420 and a code for voltage low on the bank 1 sensor 2, that turned out to be a exhaust leak, so far i've only gotten the efficiency code on a cold day, other wise i've been through over a tank of gas and only gotten the one efficiency code.
Destructo09 is offline   Reply With Quote
Old 03-06-2014, 02:47 PM   #12
ROD_SS
ROD_SS's Avatar
Didn't know this thread came back to life. Just an update, it's been a year and no codes since tuning.
Old 03-07-2014, 02:27 PM   #13
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
These codes are common when adding LT Headers, on 2013 and newer models, these codes were not there in the 12 and older models.
As the cars get newer there are more and more diagnostics running in the background.
Your car is not in any trouble.
If I can help with a Tune let me know.
I can tune it right in your Driveway via the SCT tuners.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 04-11-2014, 12:23 AM   #14
DefiantXSoldier
Drives: 2014 Red Hot 2SS/RS/1LE NPP Recaros
Ted.
Ted will the same SCT SF3 tuner that I have now for my 2010 SS work on my 2014 SS I have coming in a few weeks?
Sent from my iPad using Tapatalk
DefiantXSoldier is offline   Reply With Quote
