Cold Air Inductions
Old 06-20-2009, 02:17 PM   #1
FirstCamaro2010
Drives: none
Need Oil Capacity and Weight for V6 Please!!
i believe the capacity i saw was 7.6 quarts for the v6, is that with filter cartridge change, also do what is the recomended oil weight in the manual for the v6, thanks very much, trying to go to autozone to stock up on mobil one sale before the car comes in
FirstCamaro2010 is offline   Reply With Quote
Old 06-20-2009, 02:56 PM   #2
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
Check out the link for all info on GM Engines and Transmissions.
http://www.gm.com/experience/technology/gmpowertrain/
5W -30 GF4 for the Cadillac CTS which has the same engine.
zen is offline   Reply With Quote
Old 06-21-2009, 02:48 AM   #3
fee5fofum
fee5fofum's Avatar
Drives: 2012 CTS-V Coupe & 2SS/RS
Owners Manual section 11-2
Engine Oil w/ Filter
3.6L V6 Engine : 6-qts
6.2L V8 Engine : 8-qts
(L99 & LS3)
V6L : SAE 5w-30 GM6094M
Do Not use 10w-40,20w-50 or any other viscosity grade oil not recommended
V8L : SAE 5w-30 / GM4718M (L99 & LS3) Mobil 1 is Factory fill ..
AC Delco Filter for the V6L # PF459G/*PF2129 *easier to find (Bumper to Bumper Auto Parts @ around $5.10 ea.)
fee5fofum is offline   Reply With Quote
Old 06-21-2009, 03:04 AM   #4
Vash
Drives: 00 Blazer
Hum why are they showing a different oil part? I thought both has Mobile 1 from the factory??
Old 06-21-2009, 06:53 AM   #5
Splitter
Drives: '14 RRM 1LT/RS A6
We need a RTFM smiley, haha.
Splitter is offline   Reply With Quote
Old 06-21-2009, 09:12 AM   #6
FirstCamaro2010
Drives: none
i also thought it came with mobil one from the factory, is that not correct? and the v6 uses a filter replacement cartridge not an actual filter correct? i guess i had the capacity wrong i thought i saw in the specs for the motor it was 7.6 qts.
Old 06-22-2009, 12:40 AM   #7
fee5fofum
fee5fofum's Avatar
Mobile 1 is Factory fill only with the V8 ..
I have the 2LT / RS and had my oil and filter changed already , just like the manual states : 3.6L takes 6-qts of Dino 5w-30 w/ AC Delco filter# PF2129 ..
After a couple more oil changes (1500 & 3000) I do plan to switch to Mobil 1 at around 4000 or 5000 mi. and then change every 4500-5000 or 4-5 months which ever comes first or use the OLM @ 10-15% ....
Other Oil Filters are :
Wix / Napa Gold filter # 57090 / 7090
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 06:40 AM
Need V6 Oil Weight and Capacity Please!! FirstCamaro2010 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 0 06-20-2009 02:06 PM
