SDTW Custom Wheels & Tires
Old 03-26-2013, 09:09 PM   #1
Matt @ FSP
Matt @ FSP's Avatar
Drives: 2011 Camaro SS
FSP Go Big Or Go Home Stock Bottom - Vortech YSi, Squash, Pfadt, DSS, ECS, Alky, ID
This has been a build that our client has tailored completely custom to his setup, and actually has helped with part of the work on the car. He has allowed us to recommend only the best of the best parts, with no hesitation on putting the best components together for his street ride. The culmination of this build has been over the course of a few months (In Stages), but we just finalized the last new modifications to it over the course of the last two weeks before sending her back home!
To put this build together, a few special thanks go out... Tommy at ECS built us a transmission in one day. Frank at DSS rushed us a rearend while he was in the middle of moving. Blair made the moves at Pfadt to get us our components on 2 day air. Andy from Squash pulled a module for us luckily we grabbed the last one the shelf. Jimmy @ Vortech overnighted Sat delivery a YSi to us. FTI's great converter puts this combo all together and makes a nice hard launch on the street.
The car hits real hard on the street, paddle shift mode makes it a bit more manageable, around 4700RPM it just pulls like a LEER JET! The transmission feels rock solid, firm shifts, comfort part throttle, feels like a real race transmission on the shifts. You can light them up on every downshift pretty easily at anywhere around 100 and below. The ECS Big blower cam gives it an aggressive sound coupled with the whine of the YSi and woosh of the Vortech BV57 bypass valve. The Pfadt parts aid to the handling, and keep the car straight when the tires want to peel off the rims! DSS rearend is solid, and the 3.70 gears are fun.
2012 Camaro SS (1400 miles)
Powertrain
- Vortech YSi Supercharger Kit, 2.95" Upper, 7.9" Lower Pulley
- 10-Rib Off the Shelf Kit
- ECS Restrictor Plate & ECS Air Filter
- ECS Big Blower Camshaft
- PRC Dual Valve Spring Kit
- L99 to LS3 Conversion
- Stock Untouched Cylinder Heads, Stock Head Bolts
- Nasty Performance LS3 Valve Covers w/ Billet Standoffs
- Custom MSD Wire Set
- FSP Custom Evacuation System; Vented Valve Covers -10AN to Dual -10AN Inlet Breather Can Mounted in Bumper
- Norris PCV Catch Can w/ Inline Check Valve
- SW 1 7/8" LT Headers w/ SW Full X-Pipe Axle Back
Drivetrain
- Driveshaft Shop 9" IRS Conversion Kit
- New Style 1400HP Level 5 Axles
- Strange Center Section w/ True-Trac Posi
- 3.70 Gears
- DSS 3.5" Aluminum Shaft
- BMR Driveshaft Loop
- ECS 6L80E Transmission Built by Tommy M.
- 4-5-6 Powerglide Clutch Kit w/ Billet Hub / 3-5-R Power Pack
- FTI Triple Disc Billet Torque Converter - 3200 Stall
- ADM Trans Cooler
Suspension
- Pfadt Street Single Adj Featherlight Coilovers
- Pfadt 6061 Subframe Bushing Set
- Pfadt ZL Spec Sway Bar Set w/ HD Front Endlinks
- Pfadt Drag Spherical Upper A-Arm Bushing Set
- Pfadt Poly Lower Control Arm Bushing Set
- Pfadt Adjustable Toe Rod Kit
- Pfadt Trailing Arm Kit
- Bogart 17" Rims All Around w/ M&H Drag Radials 325/50/17
Fuel System
- Squash Dual Walbro 400 Pumper
- Injector Dynamics ID-850cc Injector Set
- Alky Control Dual Nozzle Methanol System
- FSP Custom Fuel Line Kit (-8AN Feed/-6AN Return)
- Aeromotive Fuel Rail Kit / Aeromotive A1000 Bypass Regulator
- All Lines are wrapped with 1200* + Sleeving; Run Under Modified Factory Heat Shields.
Huge thanks goes out to all of the supporters of this build including; Vortech Superchargers, Pfadt Race Engineering, Squash Fuel, Driveshaft Shop, East Coast Supercharging, Stainless Works and everyone else involved!!!
We still have some cleanup to complete underhood with hiding the coil pack wiring, etc. but figured when we swap the motor down the line better off to do so, Adadda has other trick stuff to add to that cleaning up while the motor is out
Now to the goods... Dyno'd on our Mustang MD-150 eddy load controlled dyno we saw 732rwhp / 625rwtq. This was on 16psi at the top of the pull.
Track numbers coming soon...
Matt @ FSP is offline   Reply With Quote
Old 03-26-2013, 10:10 PM   #2
02bluess
Camaro Addict
02bluess's Avatar
Drives: 2014 Camaro ZL1 SIM A6
Awesome build, Matt! Can't wait to see track times out of this setup
Paul...
2014 Camaro ZL1 SIM A6: Rotofab, VMax TB, 22% Lower Pulley, Stainless Power 1 7/8, Cat Delete, ID850s, DSteck Flex Fuel Kit, DSteck Supplemental Fuel Pump, DSteck E85 Tune
Best Timeslip: TBD
02bluess is offline   Reply With Quote
Old 03-26-2013, 10:20 PM   #3
Adadda
Drives: 2012 Camaro SS. L99
THX. For putting up with me while I was down there . Looking forward to hitting the track when y'all come up The car feels great could not be happier.
Adadda is offline   Reply With Quote
Old 03-27-2013, 06:44 AM   #4
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
looking good Matt......
Driveshaftshop is offline   Reply With Quote
Old 03-27-2013, 07:04 AM   #5
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
Awesome build
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 03-27-2013, 07:48 AM   #6
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
Nice build can't wait to see the track numbers
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 03-27-2013, 09:15 AM   #7
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Awesome
JLE58 is offline   Reply With Quote
Old 03-27-2013, 09:44 AM   #8
BLACK10
BLACK10's Avatar
congrats!
Old 03-27-2013, 10:33 AM   #9
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Top quality build. Can't wait to see the updates soon!
Old 03-27-2013, 11:32 AM   #10
East Coast Supercharging's Avatar
Drives: 8 second C5 Drag Car, C6 Road racer
Nice work guys, glad we can be a part of it!!
Doug @ ECS
East Coast Supercharging is offline   Reply With Quote
Old 03-27-2013, 02:42 PM   #11
VanquisherSS
Hasbin of Stock Bottom HP
Drives: CTS-V Coupe, 04 TT Viper
Very nice . Probably some more left in that YSI once the engine is pulled.
VanquisherSS is offline   Reply With Quote
Old 03-28-2013, 02:28 PM   #12
Matt @ FSP
Matt @ FSP's Avatar
We could remove the restrictor and make 23-24psi... But we'll have a motor on the stand before that
Old 03-28-2013, 02:45 PM   #13
Birm
Birm's Avatar
Drives: Florida Speed & Power
Nice!
Birm is offline   Reply With Quote
Old 03-28-2013, 04:25 PM   #14
XCLR8
Drives: 2010 2SS
Whats the limit with the 10-Rib before belt slip? At what point would a cog setup be needed?
XCLR8 is offline   Reply With Quote
