Emblempros
Old 03-27-2013, 11:48 AM   #1
simt3k
Drives: 2011 Camaro RS 2LT
How to take off the valve/cam covers?
Does anyone have pointers or a guide in order to take this part off? I am replacing the drivers side and input/advice would be greatly appreciated.
I am still having oil bleed all over my motor and its because the drivers side valve/cam cover is broken and cracked where the neck connects to the oil cap.
simt3k is offline   Reply With Quote
Old 03-27-2013, 11:54 AM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
KJ can chime in, he did a write up.
Lil' Nasty is offline   Reply With Quote
Old 03-27-2013, 12:04 PM   #3
simt3k
Really does anyone have a link to this write up?
Old 03-27-2013, 12:22 PM   #4
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
I took mine off to have them painted. The driver side is harder than the passenger side because there are 4 bolts in the back that are really hard to reach.
(I'm gonna try to do this by memory so bare with me)
First take off you intake manifold.
Next there are some black clips that need to be undone (these help hold all the wires) There is one on the right side if looking from the front and another right in front of the valve cover. To undue them they are clipped from the bottom and they just pop off.
After you get those off unplug the fuel injectors and use a 10mm wrench to untighten the bolts holding them in and take them out.
Then undue the bolts that hold the valve cover on. Untighten them as much as you can and then you have to pull up on them to take them off (there is a rubber thing around the attached washers that hold them in)
*I think that is everything? If you run into any problems let me know and I'll try to help
kjkjr27 is offline   Reply With Quote
Old 03-27-2013, 03:36 PM   #5
simt3k
Thanks I am just hoping I don't break anything in the process.
Old 03-27-2013, 03:52 PM   #6
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
O one more thing. Once you have all the bolts off you may need to stick a flat head inbetween where it connects to the rest of the engine to break the vacuum that is caused when the engine is running. If you see a rubber thing kinda off don't panic it is just the rubber seal that can easily be placed back into the valve cover.
Old 03-27-2013, 04:22 PM   #7
simt3k
sh** now I am uncertain of myself... lol
Old 03-27-2013, 05:53 PM   #8
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
If I can do it, you can too
Old 03-27-2013, 07:56 PM   #9
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
It will be helpful it you use a 1/4" drive ratchet with a universal joint to get those back ones. Also, a short extension.
PieNsky is offline   Reply With Quote
