JDP Motorsports
Old 03-27-2013, 01:48 PM   #1
intensifi
Drives: '12 2LT Convertible
Question Is this a catch can on the Z/28?
lower left
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 03-27-2013, 02:24 PM   #2
LeanPocket
Drives: 2010 2SS
look more like a oil return system that doubles as a catch can
LeanPocket is offline   Reply With Quote
Old 03-27-2013, 02:24 PM   #3
LeanPocket
Drives: 2010 2SS
i want that on my camaro btw
Old 03-27-2013, 02:36 PM   #4
SC2150
Dry sump tank (for the oil storage) VS a wet sump like most V8's.
You will never see a catchcan from the factory on anything less than a exotic super car.
The 1LE clean side separator is as close as it gets, and the new LT1 DI engine from GM has redesigned the PCV system for like the 12th or so time "One of the most distinctive features of the Gen V LT1 is the domed rocker covers. They haise a patent pending positive crankcase ventalation system (PCV), which enhances oil economy and life, reduces oil consumption, and contributes to low emmissions."
Which is what a good catchcan does already. great to see they are trying to reduce valve coking issues all DI engine have, but it wont stop it all.
Old 03-27-2013, 06:53 PM   #5
CyberPunk223
Drives: 2012 LS Camaro
so why is this dry sump suppose to be better than a wet sump? the damn things uses 10.5 quarts of oil so it obvisoulsy isnt to reduce weight is it?
and this "1LE clean side separator ", does it work good?
CyberPunk223 is offline   Reply With Quote
Old 03-27-2013, 07:05 PM   #6
SC2150
Hard corbering and braking causes wet sump windage (oil splashing around ) that can rob power and if you suck some air in the pickup that is a momentary starvation of oil. A dry sump is constantly supplying the same amount of oil at all times and no pickup tube in a wetsump to suck air. The more oil, the better in longevity, keeping cool, and maintaining protection properties longer.
GM first started using the dry sump with the C6 Z06 corvette (427 ci) LS7.
Old 03-27-2013, 07:24 PM   #7
Synner
Drives: not stock
Oil starvation issues with high g turns and also more oil means lower temps, road racing will see incredibly high temps that can grenade a motor/bearing.
Synner is online now   Reply With Quote
Old 04-30-2013, 06:12 PM   #8
snickerdoodle
Drives: 2013 1LE AGM 2SS RS M6
dry sump.
snickerdoodle is offline   Reply With Quote
Old 04-30-2013, 06:58 PM   #9
Sftshldr
Beast Rider
Sftshldr's Avatar
Drives: 2017 ZL1 BLK A10
For The Win
"Just looking fast is sometimes all it takes!!!"
Sftshldr is offline   Reply With Quote
