Old 03-27-2013, 07:22 PM   #1
ace32x
ace32x's Avatar
Drives: 2013 ZL1
stock lsa clutch, what are they good to?
what is the stock clutch good to? im seeing people putting down low 700 on the clutch with out swapping it out. debating porting my blower and heads though and im thinking with all my other mods going on that will put it in the 750-760 range seems like it might be pushing it on a stock clutch
C6Z06 400ci, twin gen 2 promod 88's,th400, Alky car
ace32x is offline   Reply With Quote
Old 03-27-2013, 09:05 PM   #2
ZL1terminator
ZL1terminator's Avatar
Drives: Pearl white, 2010 Premium GTR
750-760 stock blower alone is a challenge, to the crank is no problem, wheels is a different story!
I would be more worried about the LSA at that level,than our beefy clutch brotha!
Best of luck tho hope someone has a fact sided answer for you!
ZL1terminator is offline   Reply With Quote
Old 03-27-2013, 09:12 PM   #3
ace32x
ace32x's Avatar
Drives: 2013 ZL1
shouldnt be to hard with full bolt ons ported head and ported blower and 9.5 lower and 2.5 upper.
Old 03-27-2013, 11:06 PM   #4
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 13 ZL1, 15 Scat Pack,& 15 Silverado
9.5 lower and 2.5 upper isn't a good mix. The rpms for the blower will be to high.. Maybe I'm wrong but I heard it isn't safe. Sorry for thread jacking
2013 M6 ZL1.. Mods- Roto-Fab CF Intake, Ported and Polish LS7 TB and Snout, 2.55" Upper Pulley, 100mm Idler Pulley, Solid Isolator, Afco Heat Exchanger with fans, ID850 fuel injectors, SW 2" LT Headers With High Flow Cats, and CMS 91 Octane tune.. 579.8rwhp and 537.4rwtq
TripleBlkZL1 is offline   Reply With Quote
Old 03-27-2013, 11:30 PM   #5
ace32x
ace32x's Avatar
Drives: 2013 ZL1
overspins it a fair amount but if it burns up the bearings ill just rebuild it. its not my daily anyways.
talked to a few people and the shop that will be porting the blower adn snout and they think it should hold up fine
Old 03-28-2013, 12:35 PM   #6
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I have seen two blown clutches all in the mid 700 ranges so it is possible to do.
my .02 is just settle for low 700's and don't overspin the blower that far. It is out of effecienty and it buiding extra heat and take lot of power to spin.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 03-28-2013, 12:38 PM   #7
ace32x
ace32x's Avatar
Drives: 2013 ZL1
hmm thats what i was afraid of. i could not port the blower and save some money there and just do the snout and run the 9.1 lower and 2.5 upper.
Old 03-28-2013, 03:39 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
The nice thing about staying out of the 9.55 is you might now have to buy the idler relocation bracket.
2.55 and 9.1 put you just barely over the blowers recomended limit. the 8.6 lower puts you right under it. they both don't really require any extras from what I have read.
I have the 8.6 lower and 100% know it just goes on no extra parts.
you could always port the blower to try to lower IAt2 temps and just run the 8.6 if you are worried about being over powered.
that is the nice thing about boost you could dial it back if needed.
you could even try the 2.38 upper that is like 15psi in one pulley but you still have some blower rpm in the safe range on the table.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 03-28-2013, 03:49 PM   #9
ace32x
ace32x's Avatar
Drives: 2013 ZL1
i already have the 9.1 and the 2.5 sitting on my desk and the 50 mm idler. thinking at this point after doing some searching and talking ill leave the blower alone and save the $. ill wait and do that down the road when i do a clutch and ill do the heads at the same time.
Old 03-28-2013, 03:54 PM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
yeah I think the 9.1 and 2.55 would be great. you are on the edge but not way over it as far as blower RPM.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 03-28-2013, 04:00 PM   #11
ace32x
ace32x's Avatar
Drives: 2013 ZL1
if i leave the blower alone for now maybe next time i revist it ill be more apt to throw a spray bar in or do the 2.3L swap that lingenfelter is now making a snout for XD. HP is like crack will eventually want more XD. at this point i just want it faster than my last car but its going to be close with no blower work
Old 03-28-2013, 06:05 PM   #12
Mattzl1
Mattzl1's Avatar
Drives: 2013 ZL1
The 2.5 upper and 9.1 lower will definately give you a very noticable increase in power without porting the blower!
2013 ZL1 AGM, ECF, A6, sunroof, black rims
mods complete! 664 RWHP, 645 RWTQ
Ported snout, 2.5 upper, Innovators west balancer with 9.1 lower, New era intake, American Racing long tube headers with hollow cats and X pipe, KDI heat exchanger, ID850's, TS29 cam !
Mattzl1 is offline   Reply With Quote
Old 04-01-2013, 04:54 PM   #13
ace32x
ace32x's Avatar
Drives: 2013 ZL1
put down some good numbers on your a6 with a similar set up! whats the sizing on your cam?
Old 04-02-2013, 08:26 PM   #14
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Verdict??
So, is the verdict that the stock clutch in the ZL1 can handle 700RWHP? If that's the case, I'd be looking at that as a replacement for my 2012 SS clutch. Thanks!!
734RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
