Gen5DIY
Old 03-28-2013, 08:58 PM   #1
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
RWHP Question/ Gauge-Boost Question. Is my tune right?
So I just came back from tuning my Camaro SS L99 at Lethal Performance San Antonio. I installed the TVS 2300. I also have LG 1 7/8 headers, ported throttle body and no cats, factory air box with 22'' rims. My numbers came out to be 449 rwhp.475 torque. From what I have been reading I see people with the same setup has I got with 490-505 range with an automatic and 550 with the manuals. I don't think my dyno numbers should have been that low. I do feel the difference of power of course but could I be missing out on more power. They also installed my gauges as well and didn't really explain them to me but when was on cruise control the gauges would go up and down, especially the boost. I was also checking my gas mpg and it was 16mpg, I know some people are getting 23 mpg. I would really like yalls guys input to see if Im messing something.
lincoln361 is offline   Reply With Quote
Old 03-28-2013, 09:12 PM   #2
Adadda
Drives: 2012 Camaro SS. L99
Your top gauge is you Air fuel ratio AFR. Gauge that's probly. the one you see fluctuating and is normal.Just watch it while under boost to make sure u arent going lean The lower gauge is boost it reads vacuum and boost the -4 In the pic is vaccum. Anything over 0 is boost
Adadda is offline   Reply With Quote
Old 03-28-2013, 09:15 PM   #3
lincoln361
lincoln361's Avatar
What about all the mods I got. Is the rwhp accurate?
Old 03-28-2013, 09:21 PM   #4
Adadda
Looks pretty good did they tell u how much boost. Or give u a copy of the dyno. Remember
People get hung up on numbers on a dyno but at the end of the day its just a tool and you are L99. So the With the A6 thise numbers look ok
Old 03-28-2013, 09:26 PM   #5
2012REDSS
My guess is the factory air box and 22s are killing it. Look into a cai. As for the rims I can't say my I love my 22s and just cranked the boost till I hit my goal of 600.
2012REDSS is offline   Reply With Quote
Old 03-28-2013, 09:43 PM   #6
lincoln361
lincoln361's Avatar
He said I was around 5lbs boost. I didn't pulley down. I didn't know my boost would go down with headers. But I know I need to get a Cai, put my factory wheels on, and pulley down. Maybe that would get me around 500rwhp
Old 03-28-2013, 09:52 PM   #7
lincoln361
lincoln361's Avatar
How would I know if I am going lean? Thanks in advance
Old 03-28-2013, 10:06 PM   #8
08G8V8
Drives: 2008 Pontiac G8GT
You should be around 11.5 AFR at WOT. If you see AFR of 12.5 and higher, you should have them look at the tune again.
2008 PBM G8GT, TVS1900, Patrick G cam, Lonnies Double Pumper, Kooks 1 7/8 Mids, Corsa Cat-back, Patrick G Tuned, RotoFab w/ HSRK, BP Catch Can, Pedders Lowered Touring Suspension w/ sway bars
08G8V8 is offline   Reply With Quote
Old 03-28-2013, 10:09 PM   #9
lincoln361
lincoln361's Avatar
Ok, I will have to give it a shot and see what it shows lol ha ha. Thanks for the info. I appreciate it
Old 03-28-2013, 10:26 PM   #10
Chevy69er
Chevy69er's Avatar
Drives: 2011 SLP ZL-585, 13' Silverado
I made 498 rwh with just stock ls3 with maggie. 608 with lt headers and OD cog drive and rotofab intake.
Chevy69er is offline   Reply With Quote
Old 03-28-2013, 10:28 PM   #11
lincoln361
lincoln361's Avatar
Did you have the mess with the fuel injectors or anything. If you have the od cog drive, did you change out any other pulleys?
Old 03-29-2013, 08:18 AM   #12
lincoln361
lincoln361's Avatar
TTT
Old 03-29-2013, 08:42 AM   #13
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
Those numbers look fine for what you have done. As another member said, a dyno number is just a tool. There are so many variables from ambient temp, humidity, baro pressure. So don't worry about a dyno sheet.
The things to keep an eye on are Air Fuel Ratios. And by seeing how low your gas Milage is I would say you are running rich, not lean. They probably did a conservative tune for you.
What injectors do you have? If you are still on stock injectors, you will way yo upgrade them to at least 52lbs if you want to go over 500whp. Also look into a ZL1 fuel pump and ADM FPCM. When it comes to boost the last thing you want to lack on is your fuel system.
sent from my galaxy s3. that would explain the errors.
xjer22x is offline   Reply With Quote
Old 03-29-2013, 08:43 AM   #14
xjer22x
xjer22x's Avatar
sorry my phone freaked out and posted twice lol
