R1 Concepts
Old 03-29-2013, 09:00 AM   #15
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Originally Posted by xjer22x View Post
Those numbers look fine for what you have done. As another member said, a dyno number is just a tool. There are so many variables from ambient temp, humidity, baro pressure. So don't worry about a dyno sheet.
The things to keep an eye on are Air Fuel Ratios. And by seeing how low your gas Milage is I would say you are running rich, not lean. They probably did a conservative tune for you.
What injectors do you have? If you are still on stock injectors, you will way yo upgrade them to at least 52lbs if you want to go over 500whp. Also look into a ZL1 fuel pump and ADM FPCM. When it comes to boost the last thing you want to lack on is your fuel system.
sent from my galaxy s3. that would explain the errors.
I used the injectors that came with the supercharger and I believe those are the 52lb injectors. The tuner said I still had room to play with those as well. So do I still got to upgrade them since I got the 52lb injectors like you said. Also, what is a good CAI when using a supercharger. I see a lot of people using the Rotofab with the adm scoop. Would I still need the zl1 fuel pump and what is the ADM FPCM? is that the boost a pump? Thanks for replying
lincoln361 is offline   Reply With Quote
Old 03-29-2013, 04:31 PM   #16
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
You should be good with the 52lb injectors for now. I have a Turbo setup so I never used an intake, but I hear good things about the rotofab/air scoop combo.
As far as the fuel pump. Its not needed. But I feel if you are going to spend $250-300 on a BAP.. why not upgrade to the fuel pump as well.
I am running 10psi of boost with a stock fuel pump as of now with a BAP. And its fine. But I have a ZL1 fuel pump sitting on my table ready to go on. Wish it was out when I first did my Turbo kit.
The ADM FPCM( Fuel Pressure Control Module) is a replacemt computer to control the fuel pump that ADM designed. Because just dropping the fuel pump in without this piece wasn't working at its best. So on a sense its a properly tuned BAP that replaces your stock FPCM.
xjer22x is offline   Reply With Quote
Old 03-29-2013, 05:18 PM   #17
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
dont watch the guages too much they will drive you nuts or make you crash lol
the air fuel should stand straight on WOT somewhere between 11.5 and 12.5 but steady ... thats the only time "glance" at it. 14 to 15 while cruising but no need to watch it then. low numbers are rich high numbers are lean.
Mchlgrrsn is offline   Reply With Quote
Old 04-10-2013, 08:58 PM   #18
Chevy69er
Chevy69er's Avatar
Drives: 2011 SLP ZL-585, 13' Silverado
Originally Posted by lincoln361 View Post
Did you have the mess with the fuel injectors or anything. If you have the od cog drive, did you change out any other pulleys?
stock 3.8 pulley, injectors that came with the maggie and a zl1 fuel pump, no module. Duty cycle was @ 95% so in putting in 850's before i put on ported throttle body and 3.6 pulley. Should be 650 ish. Best bang for the bck is the OD cog and zl1 pump-whole nother animal!
Chevy69er is offline   Reply With Quote
Old 04-10-2013, 09:05 PM   #19
Unreal
Drives: 2006 Z06
What brand and type of dyno? 450 on a mustang dyno is probably ~500rwhp on a dynojet. Don't get caught up on numbers.
Nick
Corvette Z06 -1200ish rwhp
Old 04-10-2013, 09:06 PM   #20
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
The ZL1 pump isn't worth anything without the FPCM to make it work to its full capacity. It's less than $500 to get both.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 04-10-2013, 11:59 PM   #21
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
He said I was around 5lbs boost. I didn't pulley down. I didn't know my boost would go down with headers. But I know I need to get a Cai, put my factory wheels on, and pulley down. Maybe that would get me around 500rwhp
Thats pretty low boost. Certainly a very safe level of boost for the L99. Most of the L99s I know of running the 2300 are running 8-9 lbs and getting into that 500-550 rwhp range.
I would get a better breathing intake for sure. That right three may add 20 hp. You may also want to repulley just to get boost up a bit more. 5 lbs sounds low for even the stock pulley.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 04-11-2013, 02:33 AM   #22
lincoln361
lincoln361's Avatar
Yeah i am thinking a Rotofab Cai with the adm scoop. Im not sure wether to get a smaller size pulley maybe a 3.6 or get the OD Cog drive. I just put on the 1:1 cog drive so i can here the whine, i dont think i want to take that out. But changing out the pulley would be just as good right? Plus i had 22s while i was on the dyno so i know that hurt my numbers as well. Thanks for your response
Old 04-11-2013, 02:35 AM   #23
lincoln361
lincoln361's Avatar
I believe it was a dynojet. Im not to caught up on the numbers, just want to know that i am getting the same hp with everything i got. Everything with the next modifications i get, it will help out. Thanks
Old 04-11-2013, 01:45 PM   #24
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Just realize if you change CAI, pulley, OD cog...you gotta tune again
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 04-11-2013, 04:25 PM   #25
lincoln361
lincoln361's Avatar
If I change out the CAI intake, I don't think that I need to get a retune right? I know if I change out the pulley or the OD cog than I would have to get a retune.
Old 04-11-2013, 04:49 PM   #26
RBL
Drives: 2010 camaro 2SS
I would retune if i added any more bolt ons to a FI car but thats just me. The shop should retune you for a big discount.
www.lashwaymotorsports.com
2012 L99, whipple, Roto-Fab, Stainless Power headers, ZL1 fuel pump, cat delete.
RBL is offline   Reply With Quote
Old 04-11-2013, 04:52 PM   #27
MA2010SS
Drives: 2010 Camaro SS
You will need to get it retuned with the new intake
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 04-11-2013, 05:02 PM   #28
Detoxx03
ЯєŧąяĐ Єlímíиąŧ°я Ö
Detoxx03's Avatar
Drives: 2008 Corvette
It's a dynojet but I believe since they just moved into a new shop and got a new dyno it's a eddy current loaded version.
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
