HeadlightArmor
Old 04-03-2013, 09:17 AM   #15
Tyler360
Tyler360's Avatar
Drives: 2011 Camaro 2SS/RS
Originally Posted by fastball View Post
If I bought this car, I would remove the speaker and radio, and just fabricate a lightweight plastic or fiberglass filler panel, remove the radio, and install the panel as filler over it (painted either black or dark grey).
This car is for track purposes. So you don't need to hear the seatbelt chime, headlight reminder chime, door ajar chime, or turn signal click. You don't need music since the sound of the engine is all you want to hear anyway. Sure the feds mandate that it be there at production, but once you take possession there's nothing that says you can't take that stuff out. And it's not like you're taking this car on any long vacation trips, so you really don't need any of the modern conveniences. If you do aspire to take this car on a long drive, you're missing the point of it's existence, and I can name at least 4 cars in what will probably be the Z/28 price range that are fantastic, upscale cars that you can enjoy long distance drives in.
Unless its a Camaro, not interested...
Tyler360 is offline   Reply With Quote
Old 04-03-2013, 10:07 AM   #16
ALLTRBO
ALLTRBO's Avatar
Drives: V8 up front and 7-spd out back FTW
The ZL1 comes to mind... only it's less expensive.
ALLTRBO is offline   Reply With Quote
Old 04-03-2013, 10:47 AM   #17
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
Instead of the filler panel how about an AiM Solo lap timer? I need that way more than I'll ever need a radio in this car. And radios chassis are heavy 5-8 lbs. How do we separate the radio from the climate controls though? Looks integrated on the panel? Seeing as how I am spec'ing A/C delete all I need is a heater control
A great project for an aftermarket supplier to engineer a solution for this.
Zfatuated is offline   Reply With Quote
Old 04-03-2013, 11:18 AM   #18
fastball
White 'n Nerdy
Drives: 2017 Camaro 2SS 6MT
The outside panel of the HVAC and radio are integrated, but the internal components are separate units. When you take them out, just cut the front panel in half to separate everything.
fastball is online now   Reply With Quote
Old 04-03-2013, 11:20 AM   #19
fastball
White 'n Nerdy
Then buy an SS, 1LE, or ZL1 and save a few bucks.
You want creature comforts, I get that. If you're going to spend Z/28 money, either you don't want creature comforts at all, or you want another completely different car.
Old 04-03-2013, 12:09 PM   #20
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
Awesome, thanks for the info
Old 04-03-2013, 03:11 PM   #21
fastball
White 'n Nerdy
After thinking about it, you really can't cut the front bezel in half because the illumination of all the lights on the radio and HVAC are all interconnected, and the HVAC dials are too darn close to the radio controls to have a clean line to cut through......
BUT....
You can still remove the CD player and tuner module. The plastic bezel is just a keypad and the climate controls are all electronic, no mechanism or box inside. The bezel less than a quarter inch thick, and it weighs very little. The HVAC controls are part of the whole bezel, but the radio and CD player are not. Therefore, you can remove the bezel, take out the tuner module and CD player, and replace the front bezel.
Just make sure you don't try to accidentally put a CD through the slot, it will get stuck behind your dashboard now!
You could just tape off the CD slot from the inside while you have the bezel off.
But I definitely like your idea, that someone like Scotshe or DEI should come up with an aftermarket bezel that gives you the HVAC while just a black filler panel for the radio. They make custom trim bezels for all aftermarket head units right now anyway.
Old 04-03-2013, 04:16 PM   #22
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
Or a trim bezel with compartment to fit in a Video VBox Lite box
Old 04-03-2013, 04:29 PM   #23
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
I'd order this radio
2018 MBM ZL1 6spd Coupe https://youtu.be/fM9silIzdcI
02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles. https://youtu.be/h6faSdcvNew
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 04-03-2013, 04:33 PM   #24
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
It likely won't function. Because so many functions are electronically controlled through the radio...you can't just ditch the radio without adjusting the ECM so it won't freak out when it doesn't see the BCM is connected anymore...at least, not easily...
Old 04-03-2013, 04:54 PM   #25
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
BUT....
You could also install the Metra kit and just not install a stereo. You could fab a plate to insert in the double din and fill it with the gauges of your choice.
9/26/09 Took delivery!
Old 04-04-2013, 09:03 AM   #26
Rocky1974
Rocky1974's Avatar
Drives: 2010 RJT 2SS M6 Camaro
GM already offers a radio filler panel with switches for the COPO.
PN 22950650
And a gauge panel to replace the center AC vent.
PN 22950679
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
Rocky1974 is offline   Reply With Quote
