Old 03-30-2013, 08:34 AM   #15
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
Originally Posted by converted View Post
We loaded my neighbors lowered car on a uhaul i i think he is 1.5" lowered. Only issue we had was the splitter trying to hit in very front of trailer where the indentions are for your tires to sit in. We cut some 2x12 pieces and put in there to hold the car up over the front of the trailer. Strapped her dwn she rode fine all the way from corpus christi to lethal in louisiana.
Was there additional room left on the trailer for the items in my previous post?
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
JHall651 is offline   Reply With Quote
Old 03-30-2013, 08:36 AM   #16
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Originally Posted by JHall651 View Post
Thanks for the info. That is good to hear. Can you explain the 2x10 a little more. Do you mean plywood that is 2" thick and 10" long? Also was there any room left to strap down other stuff to the deck of the trailer? I will have my 4 stock rims and tires, stock coilovers, and stock sway bars. Do you think there will be room for me to strap that stuff down too?
He means a 2x10 piece of lumber. You know, like 2x4...
I have to do the same thing to raise the front wheels so the cats clear the top of the dove tail. In case you don't know what I mean by dove tail, it's the part of the trailer in the rear that angles down. Different trailers have different lengths to aid in getting the car on without scraping.
bannonm is offline   Reply With Quote
Old 03-30-2013, 08:42 AM   #17
JHall651
JHall651's Avatar
Thank you. I didn't know what dove tail was, very helpful. I'll be sure to get some extra pieces of lumber.
Old 04-03-2013, 10:14 AM   #18
Rick@MidwayPerformance
Drives: 2010 & 2012 Camaro SS
I use a set of drive on ramps and I back my truck up on them to reduce my break over point. This allows the splitter to clear and it wont high center when its half way up. I use the 12000 lbs rated ramps and then just toss them in the back of the truck.
Rick@MidwayPerformance is offline   Reply With Quote
Old 04-03-2013, 10:34 AM   #19
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
It's going to be a hit or miss with UHaul. I looked at those before buying my trailer and there was no way my car would fit without hitting. I'm lowered 1" and then another .35" because of tire height. My problem is the cats hitting the dove tail on the trailer. I had to buy the long Race Ramps to lessen the angle so my splitter didn't hit. You and I have the same exhaust, so you need to watch that as well.
Pete is right on with securing it using the control arms. Do not try and tie it down with the suspension as some have mentioned on this site. I loop my rachet tie-downs around the rear LCA and the front LCA. The car doesn't slide on long trips. The wheel tie-down would work well if the trailer is equipped to use them.
Here's my setup.
Damn B, you have a trailer too. I might have to come down to visit to see what else you are hiding.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 04-03-2013, 10:37 AM   #20
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
use the slightest hump to pull ur back wheels of ur truck on and with the trailer still hooked up crank it down and throw the ass of the truck up in the air . this will lower the rear of the trailer. or if there is a nice lil hill or hump thats smooth and the right angle makes it alot easier.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 04-03-2013, 01:30 PM   #21
JHall651
JHall651's Avatar
Great suggestions and ideas guys. I think I will use a combination of a few. I have ramps to drive the front of the truck up on and plus I am going to get some 2x10's. I did just find out that the trailer I am renter only has front tire straps, now for the back I am just going to chain down the rear lower control arms as per suggested in this thread. Should I rap the lca with towels or anything?
Old 04-03-2013, 02:30 PM   #22
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
ya we alway x them at the rear helps with side to side movement.
Old 04-03-2013, 03:00 PM   #23
bannonm
bannonm's Avatar
Good call. I forget to mention that. So he's saying the car rear left should be tied to the trailer's right side, and vice versa.
Also, I used small jack stands at the rear of the trailer so that when the weight of the car hits the rear of the trailer it doesn't drop. If you are close to hitting the splitter like me, this keeps the trailer from dipping. I use a bottle jack to raise the trailer to get the jacks out after the car is loaded.
Old 04-03-2013, 04:21 PM   #24
JHall651
JHall651's Avatar
Ok. Gotcha about the X strapping. I went and bought two 2" straps. Also went and looked at the trailer. It is uhaul's 7000 lbs trailer. Looks like it will be pretty easy. Even the ramps come out pretty far. The only thing that looked if'y was on the front of the trailer there is a lip where the tires bump up against and then you strap them down. That lip looked to be about 6-8" high. I hope my 1+" drop in the front does make that lip a pain. If so I thought I could always put some wood under the front tires to raise it a bit.
Old 04-04-2013, 12:03 PM   #25
JHall651
JHall651's Avatar
Wow! Thx HRD_WRK! Already trucking with some Chevy on Chevy love. All you guys were a huge help. Thanks everyone. Oh and thank you Raymonds! Name:  ImageUploadedByTapatalk1365094960.309669.jpg
Old 04-04-2013, 05:02 PM   #26
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Wow! Thx HRD_WRK! Already trucking with some Chevy on Chevy love. All you guys were a huge help. Thanks everyone. Oh and thank you Raymonds! Attachment 493563
Attachment 493564
Looks like you had to Dukes of Hazzard your way out of the car
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Alky Control
BigMatt is offline   Reply With Quote
Old 07-04-2013, 08:26 AM   #27
PMJ
Seeking 9s on M6...
PMJ's Avatar
Drives: 2012 2SS/RS LS3 aka "BlackWidow"
I have a stupid question. I'm about to buy a trailer...how do you get in and out of the car when it is on the trailer. Doesn't look like much room to open the door on any of these...
PMJ is offline   Reply With Quote
Old 07-04-2013, 08:29 AM   #28
Supercharged SS
Drives: 2010 Camaro
You spend the money on a trailer with removable fenders. On my single open trailer the drivers door will just clear the fender. On low air the door rubs.
