Old 04-04-2013, 07:38 AM   #15
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 2014 SS sedan
Originally Posted by charlie46 View Post
do you think the engine might blow up by adding a cam with a supercharger? The LS-3 does not have forged internals like the lsa motor. Just my two cents.
an ex-ford guy? I used to worry about motors popping right after I converted from Ford. LS engines are indestructible!!!
seriously have Pat G spec out a Cam for you. He is known as the Camshaft guru on LS1tech.
http://www.guerragroup.com/#!camshaft-help/c1mq5
Current toy-02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles.
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 04-04-2013, 08:15 AM   #16
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
No one comes close to Lethal and the Night Fury for N/A or boosted applications.
750 all day long on a Lethal Stage V setup
And the stock internals are fine even up to 800ish hp if tuned right.
many many high HP boost cars running around at those numbers on stock bottom ends.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 04-04-2013, 08:54 AM   #17
Alvin@PCMofNC
Drives: 2010 IOM RSS
Some of our custom cam results. Our cams are on sale right now. Last few days of a Easter sale
http://www.pcmofnc.com/index.php/blo...ilds/169-sdfwq
http://www.pcmofnc.com/index.php/blog/42-builds/153-c
http://www.pcmofnc.com/index.php/blog/42-builds/140-mc
http://www.pcmofnc.com/index.php/blog/42-builds/155-10f
We have plenty of other non 2010+ camaro builds here
Alvin@PCMofNC is offline   Reply With Quote
Old 04-04-2013, 10:32 AM   #18
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
It went from 2-3 recommendations to everyone saying theirs are the best. HA Ugh, just got complicated. Guess ill research more on above comments when I'm home and not on my phone. Appreciate the intel guys!
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 04-04-2013, 02:58 PM   #19
Mojave
2016 Camaro SS
Mojave's Avatar
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8
Originally Posted by Ryne @ CMS View Post
we have some nice cam grinds for you... a cam like in Kronix camaro would be perfect. its right at -2 degrees of overlap, therefore it has a nice soft lope, but driveability is unchanged from the stock cam... this cam has made 650rwhp multiple times, with magnuson superchargers
CMS does a great job
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4)
Some AutoX Mods Planned
https://www.youtube.com/c/MojaveKY
https://www.instagram.com/mojaveky/
https://twitter.com/MojaveKY
Mojave is offline   Reply With Quote
Old 04-04-2013, 05:02 PM   #20
SUKXOST
SUKXOST's Avatar
Anyone wanna donate a cam for the first and likely STILL only boosted 1LE in the country? Full write up review and free advertising!?!?!
PM me
Old 04-04-2013, 05:07 PM   #21
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
Livernois has a lot of great cams to choose from.
Rico is offline   Reply With Quote
Old 04-04-2013, 11:28 PM   #22
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
How much boost are you running?
gnturboray is offline   Reply With Quote
Old 04-05-2013, 04:49 AM   #23
SUKXOST
SUKXOST's Avatar
More than I'd like really but I RARELY ever go over 5500-5800 RMPs.
I hit 11lbs @ WOT
Old 04-07-2013, 03:44 PM   #24
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
whats your price range for buying a cam kit, install, tune?
2010 Camaro 2SS/RS LS3
TBD/TBD
K1 Forged Crank, K1 Forged rods, Diamond -15cc Pistons, .040 LS3 heads, Studs, Trunion upgrade, BTR valvetrain, Spartan LSX cam, Ported LS3 intake manifold, Ported 90mm TB, AGP 6262 Twins, Fore Innovations Triple pump, Flex Fuel, DW 1500cc, Mantic 9000, ZL1 short throw, DSS alum dirveshaft, DSS 1400hp axles, Strange S60 (3.54, S-trac), 1LE Shocks/Struts, Pfadt springs, BMR ZL sways, BMR LCA, Spohn Trailing arms, Spohn Toe Rods, BMR subframe connecters, Pfadt Solid Subframe mounts, Forgestar CF5V, Weld S-71, Toyo R888, MT ET Street R
blake2010ss is offline   Reply With Quote
Old 04-07-2013, 03:56 PM   #25
SUKXOST
SUKXOST's Avatar
I have a tuner and a shop to do it..... I want hardened rods as well as part of or seperate from a "kit". My tuner said off cuff that a cam might cost $200-300 for install plus $100 tuning. That was just a cam. If I threw rods in there of course it would go up I'm up for info if you have some :P
Old 04-07-2013, 08:11 PM   #26
blake2010ss
Definitely throw in pushrods and valve springs if you change the cam. Depending on the lift of the camshaft you may or may not need dual valve springs... if you want good daily driveability i would imagine .600 lift cam would be sufficient in which case a single valve spring would be plenty. I have PSI single springs in mine... i cant remember which series off the top of my head. All in all, your talking about $700-$800 for a full cam kit and whatever your tuner/installer charges.
TBD/TBD
