Jason 98 TA
Old 03-31-2013, 10:55 AM   #1
re2de2
Drives: 2012 45th
convt top wont go down
i have a 2012 camaro convt.the top wont go down but i can here the motor working whwn i press the button to raise the top.
the book list 2 fuses for the top.but the location is not right.
says passg.side trunk????
thanks don
re2de2 is offline   Reply With Quote
Old 03-31-2013, 10:56 AM   #2
Rcfiddy1
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Let dealer worry about it.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 03-31-2013, 10:58 AM   #3
re2de2
Drives: 2012 45th
i have a oppt for thursday but just curious
Old 03-31-2013, 11:03 AM   #4
HDRDTD
After you tun the handle to release the top, push up on the front edge of the top to make sure it is free of the windshield then try it.
Do you see any warning messages on the DIC?
Old 03-31-2013, 11:16 AM   #5
AbsoluteMayheM
LongTimeLurker
AbsoluteMayheM's Avatar
Drives: 2011 SIM 2SS/RS Convertible L99
The first time I put my top down it was at the dealer and he gave me the basics.
about a week later there was a break in the winter weather and it was like +5 out so i chanced it and went to put the top down. I went over the things the deal told me but when I pressed my button, nothing happened. Just heard the vert top moter running. The only thing was two little "icons" but no messages. So I did a double check.
The car was in park, the hand brake on (not needed) but just making sure. The trunk lid was closed tight. Still nothing.
I opened the trunk and then I remembered that bar/rod thing in the trunk. It was not pulled forward. I pulled it forward and locked it into place.
BINGO!
Top went down. I must have unlatched it when I was doing some Christmas shopping and forgot to put it back.
Hope this helps. Unless this bar is pulled back like in the picture below, the roof will not go down. At least it won't on my 2011.
2011 2SS/RS
AbsoluteMayheM is offline   Reply With Quote
Old 03-31-2013, 11:20 AM   #6
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 Mosaic Black Metallic ZL1
If the protective net in the trunk is retracted, the top will not go down. You might check to see if it's pulled out all the way.
hawk02 is online now   Reply With Quote
Old 03-31-2013, 11:21 AM   #7
cam62
Drives: 2012 IBM Vert 2SS/rs
BINGO!
Yes, but when the safety net is not in the correct position the convertible motor doesn't start.
O.P stated he hears the motor whine.
Make sure the latch /hooks are completely free of the windshield. If the latches don't disengage properly, it may be a fitment/alignment issue.
And yes.. take it to the dealer.
rx catch can;vmax ported throttle body;bowtie delete;SLP SS emblem;CAI cold air intake
cam62 is offline   Reply With Quote
Old 03-31-2013, 11:29 AM   #8
Goober
Drives: Camaro
thanks don
1. Take car to dealer. 2. Learn English.
Goober is offline   Reply With Quote
Old 03-31-2013, 11:29 AM   #9
re2de2
Drives: 2012 45th
great help but all is correct,unlatched,cargo net pulled,top not latched,could one of two fuse blowen???
just curious
don
Old 03-31-2013, 11:32 AM   #10
re2de2
Drives: 2012 45th
goober you must be a asshole
Old 03-31-2013, 11:46 AM   #11
pocketcthulhu
pocketcthulhu's Avatar
Drives: 2014 2ss/RS 5th gen Camaro #2
keep in mind there's a temp lock, below the mid 30's the top Will Not go down.
pocketcthulhu is offline   Reply With Quote
Old 03-31-2013, 05:00 PM   #12
Michael Rophone
Michael Rophone's Avatar
Drives: Yes
Correct, but like the cargo net, the motor doesn't run with the lockout activated.
I doubt it's a fuse. Likely a fried relay.
Michael Rophone is offline   Reply With Quote
Old 03-31-2013, 05:29 PM   #13
HDRDTD
If the window shade in the trunk is not in position, the DIC will indicate 'Top not Secure'
DAMHIKT
Old 03-31-2013, 08:19 PM   #14
BlueRay-J
BlueRay-J's Avatar
Drives: 2013 Camaro SS Convertible
Sounds funny, but don't forget to lower the top release and then twist it to release. First time for me I forgot to twist it when trying to lock the top back closed! :eek:
Sent from my DROID RAZR using Tapatalk 2
BlueRay-J is offline   Reply With Quote
