Solo Performance
Old 03-31-2013, 11:08 AM   #1
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
Tach Red Line 1LE
Ok, I searched around and didn't see anything addressing 1LE max rpm.
Why does my tachometer red line start at 6250 rpm? LS3 is 6600 right?
Perhaps that's how all SS tachs display.
Southern Comfort is offline   Reply With Quote
Old 03-31-2013, 11:13 AM   #2
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
You will always be moving reving up quicker than the mechanical tach will tell you. This way if you shift before the redline you will be at 6500-6600 since it can not keep up.
Scott@Bjorn3D is offline   Reply With Quote
Old 03-31-2013, 11:20 AM   #3
hotrodder9102
hotrodder9102's Avatar
Drives: 1992 Z28,2002 Camaro SS,2013 1LE
Probably is a safehaven fthe factory so we dont overrev these engines. The only way to really tell about the true redline is put the car on the dyno. My 2002 SS had a tach redline of 5500, but after dynoing the car, we found out that it made power up to 6400. After the tune, we set the rev limiter at 6300 to keep the valvetrain safe.
hotrodder9102 is offline   Reply With Quote
Old 03-31-2013, 11:24 AM   #4
Southern Comfort
Originally Posted by Scott@Bjorn3D View Post
You will always be moving reving up quicker than the mechanical tach will tell you. This way if you shift before the redline you will be at 6500-6000 since it can not keep up.
Thanks Scott. Did you mean 6500 to 6600 ?
So the LS3 cars have the same tach ?
Does your LE1 tach has the same red range starting at 6250?
Thanks
Old 03-31-2013, 12:27 PM   #5
hotrodder9102
Thanks
Yep...
Old 05-15-2013, 04:04 PM   #6
Michael2000
Drives: .
The Corvette tachometer with the same engine has a redline showing at 6500 rpm. Why would the Camaro be 6250? This makes no sense.
Michael
Michael2000 is offline   Reply With Quote
Old 05-15-2013, 04:07 PM   #7
bw26ss
Banned
Drives: ss camaro
what difference does it make? It probably has a different tune. I can set my rev limiter to 7000 with my tuner, but i don't because I don't want engine problems. My car pulls hard at around 4500-5000 so i don't push it.
bw26ss is offline   Reply With Quote
Old 05-15-2013, 05:07 PM   #8
Michael2000
Drives: .
What do you mean "what difference does it make"? 250 more rpm above the power peak for better performance, that's what difference it makes.
If you are shifting at 5000, you are giving away a lot of performance.
Michael
Old 05-16-2013, 12:36 AM   #9
1leNPP
Drives: 1LE , 1SS , NPP
GM may have the tach red line in the camaro marked starting at 6250 but as you can see in this video in setting 2:58 VIR track time the GM hot shoes was banging the gears off at 6500 RPM I think the stock rev limiter is set at around 6600 RPM.
1leNPP is offline   Reply With Quote
Old 05-16-2013, 01:01 AM   #10
coreyaustin17
NEC5 C-HOLE CHAMP
coreyaustin17's Avatar
Drives: 2013 camaro 2SS/RS 1LE 1 of 221
Michael
coreyaustin17 is offline   Reply With Quote
Old 05-16-2013, 01:06 AM   #11
bw26ss
Banned
Drives: ss camaro
Michael
who cares, lol.
Old 05-16-2013, 07:51 AM   #12
Scott@Bjorn3D
I usually shift right after 6K on the HUD. I have bounced the rev limiter once in 10,000 miles on my LS3 and man it made me feel like a fool.
Old 05-16-2013, 09:49 AM   #13
Michael2000
Drives: .
Great video! Thanks. I appreciate the info.
That guy is a good driver. He clicks off shifts right at 6500 like clockwork. I wonder if they have shift lights, because it looks like the tach is blocked by the steering wheel from the driver's view (dumb design). He maxes out the G's in braking and cornering consistently, too.
It's also interesting that the digital speed readout sometimes reads lower than the analog speedometer, particularly during deceleraton.
Michael
Old 05-16-2013, 09:55 AM   #14
Michael2000
Drives: .
who cares, lol.
Aren't you two late for class?
Michael
