Emblempros
Old 03-31-2013, 10:27 PM   #1
tomster
tomster's Avatar
Drives: 2018 "hyper blue" ZL1 1LE
Transmission problem...
Had a few days of warm weather and finally get to get it out and get on it a little. I have a track day coming up at mid Ohio on the 13th-14th and wanted to practice banging gears seeing how i haven't had much seat time after break in (only 1800 mile on it) Since day one of owning this car I have felt that when shifting fast its hard to to go from 2nd to 3rd.(seems like I always hit the gate area between 1st and 2nd). Also Sometimes It would go in second kinda hard. (like notchy) Well today it started grinding when shifting in to 5th. With the track day coming up I think i may just run it like this and have the dealer look at it after....
but what do you guys all think. Anyone else have any of these problems?
Also have a note worthy clunk when you transition from on to off gas or off to on gas at low speeds in first or second.
2018 ZL1 1LE (daily driver on the nice days)
tomster is offline   Reply With Quote
Old 03-31-2013, 10:54 PM   #2
John Deere Racer
John Deere Racer's Avatar
Drives: 2013 zl1 m6
Had the same trouble at the drag strip
Wouldn't go n 3rd at high rpm
2013 ZL1 M6 black on black 10 spokes
592rwhp 616rwtq bolt ons only
www.mikenorrismotorsports.com
Www.lgmotorsports.com
John Deere Racer is offline   Reply With Quote
Old 03-31-2013, 11:00 PM   #3
tomster
tomster's Avatar
what did you do to fix it?
Old 03-31-2013, 11:02 PM   #4
John Deere Racer
Drives: 2013 zl1 m6
May put a clutch resivour in
Old 04-01-2013, 07:19 PM   #5
tomster
tomster's Avatar
have an appointment with the dealer on Thursday... not looking forward to them ripping the tranny out of my brand new car. Hope they will have it done before my track day i already paid for on the 13th!
Old 04-05-2013, 11:27 PM   #6
tomster
tomster's Avatar
dealer called today stated g/m is shipping them a hole new trans. G/m wants mine back in one piece to find out what failed. They didn't even want the dealer to open it up and look.
Old 04-06-2013, 08:41 AM   #7
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
I've had the same trouble with third at high rpms. Ground the gears a couple times because it wouldn't go in and I was off the clutch too fast. Let us know of you hear anything back...I'm interested, but not sure I want a tranny replaced.
2012 ZL1: M6, Rotofab CAI, ATI balancer w/8.66 overdrive, PFADT long tube headers w/cats
2016 Silverado LTZ-Z71 Midnight Edition: 6.2L, 8 speed auto, Borla exhaust
Whos_Drivin is offline   Reply With Quote
Old 04-06-2013, 08:53 AM   #8
pumpkinrancho
COMPULSIVE CAMARO OWNER
pumpkinrancho's Avatar
Drives: 17 A10 ZL1,14 2ssrs,96,85,79,69&67
Mine does it first to second when ever i try the no lift shift. But not second to.third.
Old 04-06-2013, 09:45 AM   #9
JFWJR179
JFWJR179's Avatar
Drives: 2013 Camaro ZL1 Convertible M6
I have noticed a problem on the 1-2 shift during regular easy shifts
at low RPM's (under 1500 RPM)
This has occurred at least 25 times and the car only has 1000 easy miles
on it.
I'm gonna have the dearler adjust the shift linkage when I hit the
1500 mile break in period.
JFWJR179 is offline   Reply With Quote
Old 04-06-2013, 10:08 AM   #10
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I use to have all these same problems on my SS, I had to teach myself not to try and force the gears. Go easy with the shifts, and they will go in like butter. These trans are notchy, but that's just the way they are.
Old 04-06-2013, 10:12 AM   #11
ZL1Dave
ZL1Dave's Avatar
Drives: 2012 ZL-1 #1442
I forget which one but one of the mags that did a review on the ZL-1 commented on a similar experience with trouble shifting vigoriously so apparently its not an isolated incident and something in there could use a bit of improvment. Hopefully the aftermarket will address it in the near future. Good luck with the new trans and on the track
ZL1Dave is offline   Reply With Quote
Old 04-06-2013, 09:50 PM   #12
tomster
tomster's Avatar
I wont get my car back until this Thursday... And I am racing at Mid Ohio on sat and Sunday.. So i will def be-able to compare the new trans with the old. Maybe there is a batch of bad transmissions and their is hope for everyone with this problem
Old 04-06-2013, 09:57 PM   #13
alex70olds
alex70olds's Avatar
Drives: 2012 ZL1 #141
on it.
This is the only thing I have noticed. I believe it is when you sre close to the skip shift range. I just go up to about 2k RPM and it seems to eliminate this. I have never had any issues with 3rd.
alex70olds is offline   Reply With Quote
Old 04-06-2013, 10:17 PM   #14
tomster
tomster's Avatar
does anyone know is their a proper way to use the no lift shift when drag racing? I mean i would just clutch at 6000-6200rpm grab the next gear with out lifting the gas and drop the clutch. Is this wrong?? i tried it in all the PTM settings. Seemed that traction control would interfear in the lower settings. I found it seemed to work best with all nannies turned off. But when trying to do this seemed to cause me to most missed gears. Long story short I was more consistent with out it. (no missed gears)
