| Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions Performance driving discussions |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
L99 (best mode for racing?)
What's the best transmission mode for drag racing?
I would like to hear from the guys that are running good times what computer transmission mode you're using. 1. D - (regular drive) 2. M - (sport mode) 3. M- (sport mode using paddle shifters) 4. Competitive mode (8-37 in the owners manual) -press TCS button two times quickly. Thanks.
www.Camaro5Fest.net
Tried each and every one of those combos last night... wish I had time to complile all the numbers... maybe this evening...
The winner was S Mode... Competitive Mode... No paddle shifters Reasons were with T/C off I got wheel spin once off the line and another time using tap shift from 1st to 2nd. When I had T/C off and got no wheel spin I ran the exact same time as with T/C on. (so I prefer to be safe and leave it on - comp mode) Tap shift will take lots of practice becuse it's soooo slow to react. You have to anticipate the tap so it can really screw up a a good run (but save your motor... ) I gained nothing using it during a perfect run except for a chance to shift late and lose time.One more note... it's easier to have everything off when coming to the line... That way you can do a burnout and just pull up to the line rather than stop to double tap back to comp mode. I still prefer Comp mode |
![]() Drives: 2010 1SS/RS L99 Join Date: Oct 2008
what is the difference between competitive mode and sport mode(not using shifters)
Sport mode is a gear selection option (D, S, or M are available).
Competitive Mode is a tractio/stability control option which turns traction off and leave stability on.
2SS A6 Black
360 RWHP/382 FTLBS - tune only Mods on: Dynatech LTs, Vararam Intake, Pedders Xa's, DiabloSport tuned |
![]() Drives: 99 Hugger, 2002 Berger #70 Join Date: Oct 2008
So how do I get it to stay in 1st or 2nd gear to take it up to 3 or 4000 rpm and let it back down, it shift's on me?
#6 | |
You have to use the paddle shifters to keep the car in a gear. They are on the back of the steering wheel.
#7 | |
![]() Drives: 2010 Camaro L99 Join Date: Jul 2009
I think that's what you're asking
#8 |
[QUOTE=Ultimate Performance;706204]When you put the shifter in M(sport mode) it will shift by itself. Once you put the shifter in M(sport mode), click the + paddle and you are then in control of shifting the transmission.
I think that's what you're asking [/QUOTEI would also like to add, once you touch the tap shifters in M- Sport mode (it switches you over to manual mode). You must now shift the car yourself until you move the shifter back up to D (regular drive). When I'm done using the paddle shifters, I move the shifter quickly up to D and then back to M (Sport mode). I pretty much use M (Sport mode) for most of my daily driving. I rarely use the paddle shifters. But sometimes the paddel shifters are fun to play with. I also like using the paddle shifters when I want to hold first gear when rolling slowly off the line. And make sure you time the shifts properly when using the paddle shifters. There's a slight delay on the shifts so you can end up hitting the fuel cut off/redline if you're not paying close attention to your rpms.
#9 | |
![]() Drives: Camaro Join Date: Jun 2009
[QUOTE=SGOS252382;706303]
#10 |
[QUOTE=NativeTexan;709221]
Sport mode holds each gear a little longer (higher rpms). It also seems to shift faster. It's basically a more aggressive setting for the transmission. But to be honest, I'm not sure how much faster it makes the car run (0-60mph, 1/4 mile), but it definately makes the car feel faster.
#11 | |
Does it make a difference with the fuel efficency for daily driving? |
#12 |
When I use M (Sport Mode) the engine seems to stay in each gear to a higher rpm before upshifting (even at part throttle). So I would assume that would slightly decrease mpg. But I haven't done any actual mileage testing.
#13 |
Thanks for the info. I am planning on running on a local track next Friday. I am itching to see what she will do.
#14 |
Have fun, but Texas in the summer can be tuff on track times. I know some guys with late model GTO's that live in the Dallas area and they run pretty slow times this time of year.
#15 | |
ZZ Motorsports Sales Rep
Drives: 2010 SIM 1SS Join Date: Jul 2009
[QUOTE=SGOS252382;709555]
You want to run it in M mode in the 1/4 mile. It cut the time by .4 vs just D |
#16 |
[QUOTE=ToddSS;709715]Good to know. It definately feels faster using M (Sport mode).
#17 |
![]() Drives: 2012 camaro ss (l99) Join Date: Feb 2013
this is good to know i was wondering why mine shifted on its ownin m mode still. At a stop it says s then i take off and it shifted on me. But when i try it in paddle up from the s it was ok just didnt know thats what it was lol thought s meant from a stop lol. I was like whats the point in the paddles.
#18 |
I just love that this thread popped back up from June 2009. Wow, we've come a long way.
I had just gotten my Camaro close to 4 years ago.
#19 |
Emerald Coast Camaros
Drives: 2010 2SS/RS Camaro IOM/IO Join Date: Aug 2009
Well....I run sport mode with all nannies off. Everyone of those others slow me down. I have upgraded all my rear bushings and trailing arms and run DRs, so no wheel hop and no spin.
ECC on Facebook
2010 Camaro SS/RS IOM, IO interior, Custom Striping by Eddie's Autobody, Razzi body kit ADM CAI w/scoop/Dynatech Headers & Hi-Flow Cats/Solo Performance Exhaust, FTI 3600 Stall/Comp Cams custom grind cam/LS3 conversion/FAST 102 Intake |
#20 | |
![]() Drives: 2012 Chevrolet Camaro 2SS RS Join Date: Jun 2011
I hooked up my accelerator pedal in my car to my brake lights. I hit the gas, people behind me stop, and I'm gone.
Steven Wright |
#21 | |
lll
Drives: 2010 camaro ss L99 Join Date: Jan 2013
[QUOTE=Camero5;6294533]
in the 2010's you have to move the shifter
PERFORMANCE
DYNATECH LT 1 7/8 HEADERS, CATLESS MID PIPES, CORSA CATBACK, CAI. COLD AIR INTAKE w/ SCOOP, 1LE 3:91 GEARS, LETHAL RACING PROWLER CAM, LETHAL RACING DYNO TUNE, ENERGY CRADDLE BUSHING INSERTS, PADDLE SHIFTER RELOCATE KIT, 449RWHP/438TQ APPEARANCE COPO HOOD, ZL1 SPOILER, SLP BLACKOUT PANEL, PLASTI DIP WHEELS, HERITAGE GRILL, RETRO SS EMBLEMS, WEATHER TECH FLOOR MATS, ORANGE STITCHING |
| Thread Tools | |
| Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
| Any exhaust sound clips of L99 in 4 cylinder mode? | SubSolar | Camaro Photos | Spyshots | Video | Media Gallery | 10 | 06-07-2009 01:30 PM |
| Auto Users, use the M mode and not paddles!! | Scott@Bjorn3D | 5th Gen Camaro SS LS LT General Discussions | 19 | 05-14-2009 02:44 PM |
| COMPETITIVE MODE AND LAUNCH CONTROL (V8) DIRECTIONS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 80 | 05-02-2009 12:20 PM |
| L99 engine specifications | Tran | Wiki | 0 | 10-19-2008 11:40 AM |
