Solo Performance
Old 04-02-2013, 09:10 PM   #127
Cat988h
Cat988h's Avatar
Drives: Rally yellow 2011 Camaro 1SSRS
Silverado bowtie to the bone !!!
ATI Super Damper, Katech C5R Chain, Jannetty 470 Comp Cam, Comp Valve Springs, Mellings Oil Pump, Manley Push Rods, Comp Tringion Upgrade, Cold Air Inductions Intake, 1-7/8 American Racing Headers w Cats, MBRP 3 Inch Exhaust, RX Catch Can, Eaton Tru Trac, 3.91 OEM, DSS Drive And Half Shafts, LPW Diff Cover,3 Inch Noweeds, Amsoil Z-Rod, Tuned by Jannetty Racing
Cat988h is offline   Reply With Quote
Old 04-02-2013, 09:12 PM   #128
Spektrum
Spektrum's Avatar
Drives: 2013 2SS 1LE
I had a 2009 Mazda MX-5, best driving car ever... until I realized it was the seat making my back sore everyday. Bummer.
Spektrum is offline   Reply With Quote
Old 04-02-2013, 09:23 PM   #129
Tavo
Tavo
Drives: 2013 Camaro 2SS
Lexus IS350 - 2006 and don't miss it with my 2SS RS!
Tavo is offline   Reply With Quote
Old 04-02-2013, 09:55 PM   #130
dcam97
dcam97's Avatar
Drives: 2010 ss/rs
2007 F150
dcam97 is offline   Reply With Quote
Old 04-02-2013, 10:13 PM   #131
IOM2SSRS
Drives: 2010 Camaro 2SS/RS M6
2006 Monte Carlo SS (LS4)
I thought I would miss this car so much when I gave it up.. I haven't looked back
IOM2SSRS is offline   Reply With Quote
Old 04-02-2013, 10:50 PM   #132
007s 'Vert
Formerly Lil'BlueCoupe
007s 'Vert's Avatar
Drives: '13 2LT/RS Vert, Summit White
Originally Posted by skibik View Post
I only had 98,000 miles on mine when I traded it off. It was an excellent car until the last 5000 miles or so. I took it in and had done some routine maintenance on it including a fuel filter and then it started acting up. For years you touched the starter and it was running but after I changed the battery and the routine maintenance something happened to it. I had to crank it longer before starting. Mechanic put in a fuel pressure regulator because he pulled off the line that was attached and fuel was present, worked good for about 1 to 2 weeks and then back to hard starting. Changed fuel pump because mechanic hooked up and tested the fuel pressure and it wasn't hold pressure, again worked good for 1 to 2 weeks and it was back to hard starting. One day at work I fired it up heard a noise or thought I did, shut it off and then it wouldn't start. That ended the Monte. I enjoyed that car but when it started giving me problems it had to go and I am glad I made that decision.
Dean.
We must think alike because I have been looking for a used Wrangler for a winter vehicle but used ones up north here are way over priced. Been looking for a pickup also but same thing.
You say you changed the battery in that Monte? Ha Ha! I bet you had fun! I changed the battery too.....what a nightmare! Just about had to remove the whole dang engine to get the battery out! I even had to remove the wheel in order to access the oil filter.
And the torque steer in that car was downright scary especily with the supercharger, if you punch it on an attempt to pass someone you had better be hanging on the steering wheel and be prepared for the car to get a mind of its own and go where IT wants! I just about wrecked the frigging thing several times. With the Camaro I pass wth confidence AND with a lot more power than that Monte had.
I did like everything else about that car thpugh, it was a comfortable car with lots of room
007s 'Vert is offline   Reply With Quote
Old 04-02-2013, 11:08 PM   #133
BlueRay-J
BlueRay-J's Avatar
Drives: 2013 Camaro SS Convertible
2011 Ram 1500 Sport 4x4 Quad Cab
Sent from my DROID RAZR using Tapatalk 2
BlueRay-J is offline   Reply With Quote
Old 04-02-2013, 11:22 PM   #134
GARYSSS
GARYSSS's Avatar
Drives: 2010 2SSRS M6 Rally Yellow
Camaro did not replace anything it was just added.1968 Pontiac Lemans
TEAM LS3
GARYSSS is offline   Reply With Quote
Old 04-02-2013, 11:26 PM   #135
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
'03 Civic
Old 04-02-2013, 11:41 PM   #136
Aubrey64
Aubrey64's Avatar
Drives: 2010 Camaro LLT/RS
I was driving a 1998 Honda Civic with 175,000 miles on it. Then, my step-sister totaled that, so then I drove a 1998 Toyota 4-Runner with 250,000 miles on it! I still drive it whenever I need to take a lot of stuff with me, or whenever I take the dirt bikes to the track
Aubrey64 is offline   Reply With Quote
Old 04-02-2013, 11:56 PM   #137
IH8OPEC
ΜΟΛΩΝ ΛΑΒΕ
IH8OPEC's Avatar
Drives: 2010 VR/W 2SS/RS L99
I went from 60hp 09 smart Brabus coupe to a 10 2SS/RS!
http://www.camaro5.com/forums/image.php?type=sigpic&userid=71451&dateline=141490  0528
IH8OPEC is offline   Reply With Quote
Old 04-03-2013, 01:07 AM   #138
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
05 Cobalt
Tori
Old 04-03-2013, 01:17 AM   #139
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
2010 camaro, 2006 Jeep Cherokee owned it for a year and hated it. Before that 2005 Chevy 2500 HD crew cab 4x4 diesel, 2004 1500 gmc Sierra, 2003 gmc Sonoma, 1978 C10, 85 olds, 1986 Acura integra, 1983 Nissan pos, 83 camaro, 199? Plymouth something. More to come.
CHMSC is offline   Reply With Quote
Old 04-03-2013, 01:24 AM   #140
ghostrider77
Drives: 2013 Black Camaro 2SS/RS 1LE
1995 BMW M3, and before that a 2001 Honda S2000.
ghostrider77 is offline   Reply With Quote
