Old 04-01-2013, 08:44 PM   #1
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Crankshaft is pinned
Got the SLP pinning kit today. Nice quality drill bit, reamer, guide, bolt & new GM crank bolt. Took the intake off & moved the SC res over to make room. Also took the fans out for more clearance.
Had a very hard time getting the crank bolt out. My 120 ft/lb impact at 125 psi would not budge it. 4th gear & full parking brake, 5 ft pipe on the breaker bar and the car kept creeping toward me. Blocked the wheels, got all of my 220# fat azz on it and it finally popped loose. I can't hardly believe the sucker would ever slip even pulley'd down. Thank God for 6 pt impact sockets.
Crank is drilled & reamed, pin inserted, new GM bolt started and waiting on my torque angle meter to get here. Should be a blast trying to get 140* rotation after 39 ft/lbs.
This old coot needs more Wheaties!
Iam Broke is offline   Reply With Quote
Old 04-01-2013, 09:00 PM   #2
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I had ITGuy11 help me with mine. I don't think I could have figured it out based on my install instructions. breaking it was a pain. Impact did nothing also. Breaker bar was the way to go.
newagemuscle is offline   Reply With Quote
Old 04-01-2013, 09:07 PM   #3
Iam Broke
PHAT B33
Iam Broke's Avatar
Slp 91mm pulley & shorter belt on also, looking for 9psi.
Old 04-01-2013, 09:55 PM   #4
kissmyss03
kissmyss03's Avatar
Drives: 2011 Camaro SS 2SS/RS
That was a pain breaking loose the crank bolt. Thought I was gonna break the socket before the bolt broke loose. The rest was easy from there
2011 Camaro 2SS/RS M6
Kooks Headers, catless mids, corsa exhaust, rotofab intake, SLP TVS 2300, 3.2 pulley, blower cam, cts-v fuel pump, Vector tuned 622 RWHP 573 TQ
kissmyss03 is offline   Reply With Quote
Old 04-02-2013, 12:10 AM   #5
Dznts
Anabolic Connoisseur
Dznts's Avatar
This is the part that scares me on my upcoming install.
Old 04-02-2013, 04:27 AM   #6
MA2010SS
Drives: 2010 Camaro SS
If you put heat on it the crank bolt it comes out without a fight. Nothing crazy just some map gas does the trick
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 04-02-2013, 06:01 AM   #7
Iam Broke
PHAT B33
Iam Broke's Avatar
No MAPP here, just propane. I didn't think of it though.
Old 04-02-2013, 08:43 AM   #8
blake-b
blake-b's Avatar
Drives: Black 2010
Instead of the GM bolt, you can use the ARP bolt. It is reusable and you torque it to 235 lbs. You will need a 27mm or 1 1/16 socket in 12 point.
Old 04-02-2013, 08:49 AM   #9
Kelly@PCMofNC
Drives: 2010 RS/SS
Excellent! The first time you take out a stock bolt always seems to be the worst. MAN those things are on there tight. Nothing like a flywheel holding tool though and a huge breaker bar!
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
Old 04-02-2013, 11:22 AM   #10
Iam Broke
PHAT B33
Iam Broke's Avatar
Already got the GM bolt so it'll be going in when I get the torque degree indicator.
My torque wrench stops at 150 ft/lbs anyway. 5' pipe FTW!
Old 04-03-2013, 06:10 PM   #11
Iam Broke
PHAT B33
Iam Broke's Avatar
Bolt is torqued to 37 ft/lbs + 140*. Took the 5' pipe to get it done.
No chance to take it out today for a pull though.
Old 04-05-2013, 09:11 PM   #12
Iam Broke
PHAT B33
Iam Broke's Avatar
Got to flog it today, gained ~2psi boost. Went from 6.8-7 psi on the 98mm pulley to 8.8-9.0 psi on the 91mm. Tune is still ~3% on the rich side but IDC is at 80% on E35 and fuel pressure is holding up. It takes approx 10% more fuel for E35 97 octane than E10 93 btw.
Walked away from a Roush Mustang pretty bad. lol. Gotta find a dyno around here.
Old 04-12-2013, 02:50 PM   #13
Dznts
Dznts's Avatar
i am considering doing my install myself, but this is the part that scares me the most for some reason. damn crank bolt has me worried for some reason.
Old 04-12-2013, 03:03 PM   #14
Iam Broke
PHAT B33
Iam Broke's Avatar
Like was posted earlier, heat it up. Propane torch'd prob get it hot enough.
I wish I'd of thought of it.
