Old 04-11-2013, 11:29 PM   #29
Algeron
Algeron's Avatar
Drives: 2016 2SS/RS vert, 1998 Z28, 1991 RS
Quick update.
She is still in the shop. The top has been installed, and the recalls/updates ave been completed. However, the tinters were gone by the time everything else was done. The back window ill be tinted Friday morning, then I should get her back.
I was told the top is the updated part and that GM has discontinued the original part.
2016 Red Hot 2SS convertible Adrenaline Red interor, A8, MRC, NPP, Black Bowties, NAV
Installed Mods:
CAI intake
http://imgur.com/a/kurVF
Algeron is offline   Reply With Quote
Old 04-12-2013, 07:34 PM   #30
angrykiller1
angrykiller1's Avatar
Drives: 2011 2ss inferno orange convertible
my first 4 tops were a shambles. when they replace the top, they get the water bag out of sorts, and then wet carpet every wash or rain. two years of trying to get my car fixed. hope you have better luck.
angrykiller1 is offline   Reply With Quote
Old 04-13-2013, 12:04 AM   #31
Algeron
Algeron's Avatar
As do I.
I picked her up at 530 today. This top looks tighter on the frame, but could just be that it is new. It rained all day today, and I did not see any puddles on the floor, but I will be going over her with a fine tooth comb tomorrow.
Installed Mods:
CAI intake
Old 04-13-2013, 12:34 AM   #32
intensifi
Drives: '12 2LT Convertible
good luck!
please post the part numbers of the installed kit. They should be on your invoice.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 04-13-2013, 03:23 AM   #33
Michael Rophone
Michael Rophone's Avatar
Drives: Yes
Originally Posted by Algeron View Post
As do I.
You've got to feel the carpet on both sides of the backseat floor.
A small amount of water can soak the carpet padding, but not make a visible puddle.
Michael Rophone is offline   Reply With Quote
Old 04-13-2013, 09:27 AM   #34
Bpw72
Bpw72's Avatar
Drives: 2011 camaro ss convertible 2ss/rs
I just had mine replaced this week. I got it back yesterday, it is quoted as a 6 hour job but it took them 5 days to get it back to me. The dealer did this themselves which they clearly didn't know how to do. They leak tested it into day 3 and found it was draining into the car. They had some specialist come in to fix that. They did put the recall kit in but I did not ask for any part numbers. A simple cover in the trunk was not put back together properly (lazily looked over) and there is a rattle of a piece of metal in the side of my car that is either something that was dropped down there or something that is loose. They also put a big scratch in the "A" pillar, filled it with touch up paint and were not going to tell me about it. As if I wouldn't notice. Going back Monday to see how they are going to remedy all of this. Had to leave when I picked it up before I really lost it.
Bpw72 is offline   Reply With Quote
Old 04-13-2013, 09:42 AM   #35
95birdible
95birdible's Avatar
Drives: 2012 1SS Camaro Convertible
If you are not satisfied at the time you go to pick your car up, leave it there until it is 100% to your satisfaction. If you take it home, the dealerships will try and say the problems were caused by you. This way, they cannot do that and as a bonus, time at the dealership counts toward the lemon law.
2012 1SS Crystal Red Convertible
"Cherry Bomb"
Winner of the #NameThatCamaro Spring Special Edition
"Green Flash"
95birdible is offline   Reply With Quote
Old 04-13-2013, 11:28 AM   #36
Algeron
Algeron's Avatar
Decided to take a quick drive around the block with the top down. The new top has several tethers that were not present on the old top and when down, it does not flap like the old top at speeds under 50 mph (in a city, fast as I could get). However, once I had the top down, and I could see in the car, I noticed some trash in the passenger seat (looked like top clippings). When I moved it, I found...
Needless to say, I will be calling back on Monday.
Installed Mods:
CAI intake
Old 04-13-2013, 11:44 AM   #37
intensifi
The top install shop owner my dealer uses told me how the retrofit procedure says to remove the mechanism and do the work outside the car. However some one taking short cuts might not do this. This issue is the new top canvas install requires drilling holes into the mechanism for the new teathers. If those drill shavings fall into the seat and are pressed in or hastily pulled out ...
Look very carefully in the seat creases or junction with the body panels for more metal shavings.
Old 04-13-2013, 12:46 PM   #38
Michael Rophone
Drives: Yes
...When I moved it, I found...
Be prepared for: "That wasn't there when we returned the car to you."
Old 04-13-2013, 02:11 PM   #39
Algeron
Algeron's Avatar
For now...I am going to look at this positively, and hope that is not the direction this takes.
I will give an update on Monday.
Installed Mods:
CAI intake
Old 04-13-2013, 02:15 PM   #40
Algeron
Algeron's Avatar
More issues....
Anyone know what this is? I want to think it was something that was cut off to remove the old top, and when cut, it wedged itself in my spoiler, since I know this was not there when the car was dropped off, and it was too tightly wedged to "fall" on the car since it was returned to me. But...I have never seen on of these before.
Chip in paint after it was removed.
Close up shot.
Of course, I will be asking the dealer about this on Monday as well.
Installed Mods:
CAI intake
Old 04-13-2013, 05:56 PM   #41
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2016 2LT/RS Hyper Blue Vert Camaro
I've got 3 or 4 of those little metal pieces myself. Found them after having the top replaced recently - they were on the backseats
classicrockr is offline   Reply With Quote
Old 04-13-2013, 06:28 PM   #42
Algeron
Algeron's Avatar
In that case, I am assuming that they are pop rivets that are used in the top attachment process, and when they cut this one, it was shot at the spoiler and embedded itself there.
I love taking a car in for 1 problem and getting a whole slew of new ones after.
Installed Mods:
CAI intake
