Cold Air Inductions
Old 04-02-2013, 09:34 AM   #1
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Brand New JDP Halo Kit
JDP's halo kit is currently backordered, but I have a brand new one here. If someone wants the kit without waiting, I'll take $300 shipped. Thanks.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 04-03-2013, 04:32 PM   #2
yotaman96
yotaman96's Avatar
I'll do $275 shipped. Otherwise, I'll just keep them.
Old 04-04-2013, 12:53 AM   #3
SolomonAKOO
SolomonAKOO's Avatar
Drives: 2011 2SS/RS
Pm sent
1 7/8" TSP headers straight piped, Custom Tick Performance cam w/ supporting mods, 1" BMR springs and other BMR suspension mods. Tuned with HPtuners by Matt@FSP
SolomonAKOO is offline   Reply With Quote
Old 04-07-2013, 09:49 PM   #4
yotaman96
yotaman96's Avatar
Thought these were sold, but I guess not.
Old 04-07-2013, 10:02 PM   #5
Smokye
Drives: 2013 SW 2SS/RS M6
How hard is the install?
Smokye is offline   Reply With Quote
Old 04-07-2013, 11:30 PM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Its not hard at all, and bump for a good deal.
Old 04-07-2013, 11:32 PM   #7
CamaroDIYking
Drives: 2010 Camaro 2SS/RS
How do you install without baking open...?
2010 2SS/RS- every option possible in 2010
Lighting- LED footwell, grille, trunk, and engine lights done via DIY. LED dome, DRL, and tag lights.
Paint- Painted engine cover, steering wheel bezel, speedometer bezel, front bowtie, tail light bezels, wheel center caps.
Exterior lights- tinted tail lights and sidemarker lights.
Wheels- powdercoated stock RS 20' wheels black
Exhaust- Cat-back Dynomax Bullet Exhaust system with bullet muffler delete.
Misc- rear blackout kit from Big Worm Graphix, black side Camaro lettering from Emblem Pros, and rear Camaro lettering from Emblem Pros.
CamaroDIYking is offline   Reply With Quote
Old 04-08-2013, 09:30 AM   #8
yotaman96
yotaman96's Avatar
It's all in the included DVD.
Old 04-08-2013, 09:39 AM   #9
CamaroDIYking
I'd like to see it though. Cause I'd want to watch how to do it before I bought them.
Old 04-08-2013, 09:42 AM   #10
01pewterz28
Camaro Junkie
01pewterz28's Avatar
You pull the front bumper off, then the actual metal bumper cross bar (you mount the control box on this) remove each head light, unscrew the backing to get access to the bulb area/LED, you cut the old LED wires, unscrew the 3 screws holding the factory LED in place, next replace the factory LED with the JDP LED put the screws back in place, connect the wires, seal up the headlight, run the wiring harness from the engine compartment thru the firewall into the passenger cabin hook up the interior LED, and the switch, plug in the wiring harneness to the new LED's on each headlamp, plug in the two plugs into the fuse panel, re-install everything and you are all set. It should take you approx. 3 hours from start to finish I have done two so far.
**FIFTY HBM 2SS VERT**
Old 04-16-2013, 11:18 PM   #11
mikey1107
mikey1107's Avatar
Drives: 2012 ZL1
Pm sent
Sent from my iPhone
2017 SW SS 1LE
2012 AGM ZL1 M6 #574-SOLD
2010 SW 1SS/RS-SOLD
mikey1107 is offline   Reply With Quote
Old 04-16-2013, 11:29 PM   #12
yotaman96
yotaman96's Avatar
Sold!!!!
Old 04-16-2013, 11:30 PM   #13
mikey1107
mikey1107's Avatar
Drives: 2012 ZL1
Originally Posted by yotaman96 View Post
Sold!!!!
To me!!
Thanks
Sent from my iPhone
2017 SW SS 1LE
2010 SW 1SS/RS-SOLD
