JDP Motorsports
Old 05-17-2013, 09:59 PM   #71
GRAHL
workaholic
GRAHL's Avatar
Drives: 69 SS Lemans Blue
Originally Posted by 2cnd chance View Post
I prefer pounds per HP. We still don't know the Z/28's weight but it could be as low as 3,700. Also if we're talking RWHP the LS7 is as high as 480+ That's 7.7 lbs per RWHP. That's quite awesome.
Everything about the car is awesome!!
GRAHL is offline   Reply With Quote
Old 05-17-2013, 10:03 PM   #72
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
From what I've "learned" from you guys is that the hi-speed, aerodynamics isn't really that much of a factor on these on these cars for the type of tracks that are usually run...high end top speed is rarely reached and won't give the ZL-1 a real "advantage" there.....
Good to hear from ZL-1 guys though for a change....lol
90503 is offline   Reply With Quote
Old 05-17-2013, 10:10 PM   #73
ZLFUN
Drives: 2013 Camaro ZL1 Coupe
Not sure an engine can really determine RWHP... that is really transmission and drive train losses I would think. Don't know how the 3.73 rear end in the ZL1 would compare to the lower gears in the Z/28 for losses, but I can't imagine 480 RWHP on a 505 BHP rated engine. I could be wrong.
Anyway, good point on the ratios... lb/hp works better outside a spread sheet to be sure
580hp/4120 lb = 0.1408 or 7.1 lb/hp ZL1
505hp/3800 lb = .1329 or 7.52 lb/hp Z28
3590 lbs z/28 505hp/3590 lb=0.1407 or 7.1 lb/hp
Z06 Vette 505hp/3175 lbs= .1591 or 6.3 lb/hp Z06
ducati Panigale w/termis: 203hp/407lb = .4988 or 2.0 lb/hp !!! (Get's worse with my fat backside strapped to it (about 3 lb/hp but still...
ZLFUN is offline   Reply With Quote
Old 05-17-2013, 10:11 PM   #74
366250
Drives: 1970 Chevelle
Dear GM,
Please offer the LS7, with dry sump, and appropriate drive train as a Camaro SS or 1LE power train option.
Thank you!
366250 is offline   Reply With Quote
Old 05-17-2013, 10:15 PM   #75
ShnOmac
ShnOmac's Avatar
Originally Posted by 366250 View Post
Dear GM,
Thank you!
While I would like to see it as a option it's more than likely not going to happen. GM's Fleet average (MPG) would suffer severely with loads of LS7's running around town.
ShnOmac is offline   Reply With Quote
Old 05-17-2013, 10:29 PM   #76
NightmareZL1
Can't stop ***ifying
NightmareZL1's Avatar
Drives: Ashen 2013 Gray ZL1
Rear wheel on the ls7 vettes is always 460 give or take a couple. That's with a shorter drivetrain and special rear transaxle. The Z28 will have less rwhp because of more shtuff to spin under there plus a longer (little heavier) driveshaft. And, it will be toting around several hundred lbs. I hope it isn't something dismal like 425 rear wheel - have a feeling that's what will be seen.
Rotofab, grinding rear diff sound forever, dealer replaced supercharger - now i have a rattle when starting from a stop, ordered 2.35 lingenfelter pulley, hp tuner, belt, 100mm idler pulley, tr7IX spark plugs, wideband kit, long tubes with no cats...hoping for 650hp. dyno with rotofab = 518hp
NightmareZL1 is offline   Reply With Quote
Old 05-17-2013, 11:11 PM   #77
Col. Brain
Drives: 2012 Ram 1980 Malibu
you know the COPO's 427 is rated at 450hp
Col. Brain is offline   Reply With Quote
Old 05-17-2013, 11:22 PM   #78
NightmareZL1
http://www.tbssowners.com/forums/showthread.php?t=91479
Per Chevy performance, we have 425. (engine? wheel?) looks to be engine. car probably has a super stout bottom end that is waiting for huge power upgrades. and the weight, OMG.
EDIT, after looking at what is inside that 427 copo engine, and at the fact that it spins to 8000rpm, that thing is making HUGE power. 600? 700? on a 3200lbs chassis. Holy geez. why do they give the Z28 the 505 hp (7 year old Z06 engine design) when they can bump power up that high in an LS7.
Old 05-18-2013, 12:29 AM   #79
Squillo
Squillo's Avatar
Drives: 2013 Camaro 2SS/RS BRM LS3
I'd like to see the comparison with the same tires on the Z/28 and ZL1.
Performance
AirAid CAI
Apex Motorsports ported spiraled Throttle Body
Kooks 1 7/8" LT headers and 3" mid-pipes (cat delete)
Hurst shifter
Dyno Tune
Cosmetic
Camaro badge GOBO door lights
"SS" badge GOBO hood and trunk lights
Blacked out side markers with 30% tint
Blacked out tail lights with 30% tint
Afterburner tail lights
Blue / white color changing headlight and foglight HALOs
Blue LED upper and lower grille accent lights
30% tint windows
Plasma fog light bulbs
DRL harness
"BDMFER" Hawaii state issued license plates
"Bad Mother****er" custom blue lighted door sills
Blacked out bow ties
Squillo is offline   Reply With Quote
Old 05-18-2013, 12:36 AM   #80
stlrammer
stlrammer's Avatar
Drives: 2017 2LT/RS Yellow
I could get really excited about the Z-28 if we could ditch the tail lights.
stlrammer is offline   Reply With Quote
Old 05-18-2013, 03:12 AM   #81
jashobbsie
Davenport Stage 5+
jashobbsie's Avatar
Drives: Camaro ZL1 & C7 Corvette 3LT Z51
so glad i bought a ZL1... I not really digging the style of this car at all... I'll say it again, I hate the new changes... faster or not...its just not for me. I've been doing some reading on this car just because I'm curious of what they did to it....sounds like everything fun about the camaro has been sucked out of it... but if you are a strictly track guy...go for it.
cheers!
jashobbsie is offline   Reply With Quote
Old 05-18-2013, 06:08 AM   #82
GRAHL
workaholic
GRAHL's Avatar
cheers!
Lets see we shed weight, added the high-revving fire-breathing torque monster ls7 under the hood, recaro seats, finely-engineered track-tuned suspension, and supercar performance (so far even better than the zl1). Considering camaro was always for guys looking for performance I'd say GM put everything fun about camaro back INTO the car! Cheers!
Old 05-18-2013, 08:01 AM   #83
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
Put the Z/28 tires and brakes on the ZL1 and - Voila - the 3 seconds will disappear like magic! And you can still listen to your favorite radio station and drive in comfort on a hot day! LOL ...
htron50 is offline   Reply With Quote
Old 05-18-2013, 09:01 AM   #84
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
I always thought the ZL1 and Z/28 were not meant to appeal to the same buyers... Same as the V6 and SS don't appeal to the same people. All this infighting is starting to sound a lot like the V8 vs V6 threads....
Just be glad we all have a choice....V6, SS, SS 1LE, Z/28, and ZL1... What a lineup! Something for everyone.
The Bird is the word!
