Caryle Racing
Old 04-02-2013, 03:07 PM   #1
carpleror
Drives: Nissan 350Z
Camaro handling compared to other performance cars?
Ok, so I've been searching through this forum for a while now and decided to join so I could make a thread for a topic I haven't seen before; how the Camaro actually handles compared to other performance cars. I see a lot of discussion about HP and such (mainly compared to the mustang), but how does it actually drive; suspension, steering wheel stiffness, etc.? I'm looking into getting a Camaro pretty soon and the reason I ask is because I'm currently driving a 2005 Nissan 350Z and I LOVE the way it drives. The car hugs the road, and the steering wheel is VERY stiff. And, of course, it's got a lot power. So I'm curious as to how the Z would compare to an LS Camaro (which is what I'm looking into). I know the Camaro has about 50 more HP than the Z, but it's also like 600 lbs heavier, so I'm sure that translates into a decrease in performance right there. I'm expecting lower performance with this switch (which I'm ok with because I love the Camaro), I just want an idea of how big a difference there is in the performance of the two cars. I know the only way to really tell would be to actually drive a Camaro, but until then I figured this would be a good start. Thanks guys!
carpleror is offline   Reply With Quote
Old 04-02-2013, 03:11 PM   #2
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Well i may be partial but my 1LE kicks @ss its like one of the best handling cars on the road.Have you seen any of the videos i posted from Laguna seca?
cornerspeed92 is offline   Reply With Quote
Old 04-02-2013, 03:13 PM   #3
The IOM Ninja
Drives: 10' IOM 2SS/RS, 13' GB Shelby GT500
You will not be impressed with the V6 Camaro's handling compared to the Nissan. As an owner of a 350Z those things are like go-karts they do whatever you want no matter what. The Camaro handles like a freaking boat unless you get the 1LE or ZL1 (Z/28 isn't out yet). The V6 might have similar lap times to your 350Z (though I seriously doubt it) but around corners it will not feel as flat or well maintained I can guarantee it.
The IOM Ninja is offline   Reply With Quote
Old 04-02-2013, 03:16 PM   #4
SPCBA
Drives: pleather and Chiclets
if you think the z handles well and has "a lot of power" then the camaro wont disappoint. my wifes accord is quicker and handles better than a z......
why a v6 tho? ss1le is a phenominal car for the price
SPCBA is offline   Reply With Quote
Old 04-02-2013, 03:19 PM   #5
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I don't think it'll be as much of a drop in performance as you might think. The LS is very nimble, but might not be as stiff as your 350z. If you feel like it - that's EASILY fixed with some inexpensive aftermarket parts like springs and sway bars.
Mr. Wyndham is online now   Reply With Quote
Old 04-02-2013, 03:23 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
Best thing to do would be to go to a dealership and take an LS for a test drive.
Personally, I think an LS vs 350z will probably disappoint you. However, that's just my opinion. You may feel it is comparable...then again maybe not. This is why the best thing would be to test drive one and make the decision for yourself.
Build Journal
Old 04-02-2013, 03:26 PM   #7
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
Get a 1le
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w
woodside783 is offline   Reply With Quote
Old 04-02-2013, 03:34 PM   #8
amz
Factory Correct
amz's Avatar
Drives: 2011 2SS/RS
Tracks or Roads ?
I can say that the independent rear end helps a ton , on real life roads.Especially in a bumpy fast turn.
A big jump from previous generation Camaros.
On the track, it is super smooth, and can make a silly amateur look very good.
amz is offline   Reply With Quote
Old 04-02-2013, 03:35 PM   #9
plus1zero
Back in a V8 ;)
plus1zero's Avatar
Drives: 2013 F-150 5.0 4X4 Screw PAST 2LTRS
One of my coworkers drives a z vert, 2004 model. He had a few mods done, showing me how it felt and how much quicker he thought it was.
Honestly, didn't feel much if any faster than mine.
plus1zero is offline   Reply With Quote
Old 04-02-2013, 04:23 PM   #10
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
For sure look at the 1LE. You will not be happy going from a 350Z to a base camaro.
CamaroTom is offline   Reply With Quote
Old 04-02-2013, 04:26 PM   #11
Brandonmos
Brandonmos's Avatar
minor jack- Something i wonder alot, how do our cars deal real world against the other performance cars out there handling wise? basically does the 1LE handle great for a camaro, or great in general..?
Killed so many water bottles that day...
Brandonmos is offline   Reply With Quote
Old 04-02-2013, 04:28 PM   #12
Mr. Wyndham
Great in general.
Take a look at the sort of company the 1LE is in when setting lap times around VIR:
http://www.caranddriver.com/features...o-2013-page-10
And it's said (for what it's worth)...the Z/28 is three seconds faster than the ZL1.
Old 04-02-2013, 04:32 PM   #13
Brandonmos
Brandonmos's Avatar
Originally Posted by Mr. Wyndham View Post
Great in general.
I had no idea....
Old 04-02-2013, 04:41 PM   #14
toehead93
Drives: 2014 2SS/1LE
Where have you been the last 6 months? You even have one...
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
2ls, 350z, camaro ls, handling, performance
