Old 04-02-2013, 03:02 PM   #1
granatl
granatl's Avatar
Drives: 2SS RS ABM A6
L99->LS3 conversion, cam sensor error
I've taken out my L99 and had a true LS3 built for it. The cam sensor is tripping a CEL, but I don't have the error in front of me. I have the cam sensor intended for the LS3, so do I need to do some reprogramming in HP Tuners? Someone thought the interruptor ring is different between the two engines.
FYI, I used my 5-wire cam sensor/phaser harness from the original engine, and plugged that into the new cam sensor (and just taped off the phaser plug).
Jack Bilger
granatl is offline   Reply With Quote
Old 04-03-2013, 10:01 AM   #2
granatl
granatl's Avatar
I think I've found my answer. Either just disable the P0010 code (easiest way for me), or put a 10 ohm resistor across the terminals of the plug that used to go to the cam actuator (untested, but suspect that it would work).
Jack Bilger
Old 04-03-2013, 10:53 AM   #3
Kelly@PCMofNC
Drives: 2010 RS/SS
Which cam sprocket did you use? Is it starting funny or does it run fine? Let us know that code also when you have a moment.
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
