Caryle Racing
Old 04-02-2013, 07:11 PM   #1
LINMUP
Drives: 1982 Z28
500HP?
So GM is rating the Z28 at 500HP. Doesn't that seem low? I would guess that with the edition of a factory CAI and CNC's heads it would be closer to 530-540...or am I way off?
LINMUP is offline   Reply With Quote
Old 04-02-2013, 07:27 PM   #2
Unreal
Drives: 2006 Z06
LS7 heads have always been CNC'd.
Nick
Corvette Z06 -1200ish rwhp
Old 04-02-2013, 07:44 PM   #3
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
GM usually gives a lower number than they expect.
Old 04-02-2013, 08:12 PM   #4
KKreme15
KKreme15's Avatar
Drives: C6 Z06
They said 550 estimate when the zl1 was unveiled. Ended up being 580
KKreme15 is offline   Reply With Quote
Old 04-02-2013, 08:15 PM   #5
Kluch
Drives: CTS-V
They are saying at LEAST 500 HP. They said at LEAST 550 HP for ZL1
Kluch is offline   Reply With Quote
Old 04-02-2013, 08:26 PM   #6
Gary B
Gary B's Avatar
Drives: Subaru
"At least 500" keeps the door open to what the blue oval boys may do.
Time for a new ride soon....6th Gen or 5th Gen Z28? Hmmm....
Gary B is offline   Reply With Quote
Old 04-02-2013, 08:33 PM   #7
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
Well we know in the Covette it's 505.
The hope, if there is any, is that Camaro intake and exhaust breath better than the Corvette.
But I also doubt GM would spend the money to go recertify it. Having an advertisable HP number is nearly meaningless simply by having the LS7.
The ZL1 needed a bigger number to compete wth the GT500 and as it turned out they were right to do so.
I'd be shocked if you saw more than the current certified 505 for the LS7.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 04-02-2013, 10:15 PM   #8
KKreme15
KKreme15's Avatar
Drives: C6 Z06
They can advertise whatever HP number they want, they just won't say it's SAE certified
Old 04-02-2013, 10:24 PM   #9
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I don't think Ford has anything to fight back against this one...
IMO...on paper, the hp is meaningless, because there's always the ZL1 with more at 580...the hp junkies will gravitate towards that car.
The Z/28, on the other hand...isn't meant for high volume sales, and chances are only those who really understand it's purpose and value will buy it. These people care about lateral G's...brake equipment, and lap times...they know horsepower is just a part of the overall formula.
Chances are...imho...the addition of the CAI, and 3" exhaust all the way back will result in a 510-520 hp car...I think. But No. 3 could be completely right in saying it might not be recertified...
Old 04-03-2013, 10:42 AM   #10
LINMUP
Drives: 1982 Z28
That I never new...thanks for the info... I guess the CAI that the Z28 has is probably the equivalent to what the Z06 runs then...there goes my thinking on this topic lol
Old 04-03-2013, 11:10 AM   #11
MikeSVX
The magic smoke genie....
MikeSVX's Avatar
Drives: Jewels (2010 RJT 1SS)
I'm guessing they are "estimating" a 5 hp loss due to the different exhaust. The LS7 makes 505hp in the Z06.
MikeSVX is offline   Reply With Quote
Old 04-03-2013, 12:19 PM   #12
Number 3
Number 3's Avatar
GM's policy is to use SAE certified numbers only. So they can't advertise more than it makes. But it would be ok if it really made more. Refer to the 3.6L history. They used the certified CTS number until they re certified.
Old 04-03-2013, 03:55 PM   #13
Richy_Rich
FAVOR
Richy_Rich's Avatar
Drives: Many Different Rides
Z06's repeatedly see 460-470 on the dyno stock... that's about 550 on the fly.
for $60K, this needs to be the engine code:
Please be kind when you drive; thank you.
Richy_Rich is offline   Reply With Quote
Old 04-05-2013, 07:15 PM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I'm not 100% on how the test works, but as I understand it you have a window (no more than a couple percent) that you can pick your advertised power from. I imagine that the LS7 was rated as conservatively as possible with the SAE test procedure, since I'm pretty sure it was the first engine that was certified with that procedure. If all that is true (which it might not be), they would have enough leeway to rate it at 515 or so without having to actually recertify it. I don't know if SAE allows such a thing to happen, but it is a potential loophole they could exploit.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
