Old 04-02-2013, 08:10 PM   #1
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Best drag radials, MT or Nitto?
I'm looking for a set of drag radials to mount on my stock ZL1 wheels. After searching this site, the two I'm considering are the Mickey Thompson ET Street Radial II - 305/35/20's and the NITTO Extreme Performance NT05R Drag Radial - 315/35/20.
But looking at the two side by side, I'm having a hard time believing that the MT grips better than the Nittos. Am I on crack??
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 04-02-2013, 08:30 PM   #2
Tim B
Drives: 2013 ZL1 / 2008 z51 vette
I just ordered a set of the MT,s mainly due to Stephens recommendation. I got them thru Jegs and they should be here and mounted tomorrow. If the weather stays nice I should have some track results Friday night. Tim
2013 Blk M6 ZL1 685 whp / 11.32 so far
Tim B is offline   Reply With Quote
Old 04-02-2013, 08:42 PM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
I have used both and must say there is something to the rubber compound itself vs the tread design. The Nittos aren't bad but the M/Ts are much stickier and overall better. You won't be disappointed with the M/T drag radial. The ones I have never tried are M&H drag radial(had used their racemaster bias ply many times with success) or Hoosier drag radial(have used the quick time pro with great results). The last two may not have sizes that will work well with our 17,18, or 20 inch options.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-02-2013, 08:48 PM   #4
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
Would these be good for daily driving?
Rico is offline   Reply With Quote
Old 04-02-2013, 09:23 PM   #5
12 ZL1 #1725
12 ZL1 #1725's Avatar
Drives: 2012 ZL1 Black 6M
I've had both.... M/T definitely grip better... But don't like how the fit on a ZL1 rim... Rim sticks out further then tire.... Nt05R protect rim better.... But like I said M/T definitely hooks up better...
Sit Back and Enjoy The Ride!!
12 ZL1 #1725 is offline   Reply With Quote
Old 04-02-2013, 09:26 PM   #6
AZ-ZL1
Dry Heat My @ss
AZ-ZL1's Avatar
Drives: 2012 ZL1 SUMMIT WHITE
I'd like to know this too, some on the CTS forum say yes
AZ-ZL1 is offline   Reply With Quote
Old 04-02-2013, 10:06 PM   #7
Stephen12ZL1
Drives: '17 ZL1 A10
I'd say ok as long as it isn't too wet. My opinion is to get 18" wheels and swap rear wheels for the drag strip.
Old 04-02-2013, 10:34 PM   #8
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
I've had both. There's no comparison, the MT hook better.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 04-02-2013, 10:55 PM   #9
Blown355
Blown355's Avatar
MT it is. I appreciate everyone's input.
2017 ZL1
A10
Redhot with stripe
Old 04-02-2013, 11:04 PM   #10
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
Old 04-07-2013, 09:47 AM   #11
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
ive had my nitto555r's on for about 2k miles and they drive great even in the rain. dry road launches they are 100% improvement although they will still break loose just not as bad as factory tires. the handling is a little sacrificed as on high speed tight turns it feels like the car just cant handle the G's as well as it did on all 4 goodyears. i put factory goodyears on front only and nitto555r's on back all factory size
joes407 is offline   Reply With Quote
Old 04-07-2013, 10:05 AM   #12
yotaman96
yotaman96's Avatar
Originally Posted by joes407 View Post
ive had my nitto555r's on for about 2000k miles and they drive great even in the rain. dry road launches they are 100% improvement although they will still break loose just not as bad as factory tires. the handling is a little sacrificed as on high speed tight turns it feels like the car just cant handle the G's as well as it did on all 4 goodyears. i put factory goodyears on front only and nitto555r's on back all factory size
Two million miles is a lot.
Old 04-08-2013, 06:35 AM   #13
tmandoug1
Deep Sea
tmandoug1's Avatar
Drives: 2012 Camaro ZL1
tmandoug1 is offline   Reply With Quote
Old 04-08-2013, 01:04 PM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
MT's tend to hook better but wear out faster. Also look at the tread wear ratings of tires.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
