ADM PERFORMANCE
Old 04-02-2013, 09:52 PM   #1
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Nitrous tuning HP Tuners Question
I need to make a tune for 100 and 150 shot. I am aware that would be 4 - 6 degrees pulled. My question is, where or what table do I pull from and what rpm range? I am running a progressive contoller that will start at 3000 rpm or so and cutoff at around 6000 so I can shift.
I am fighting what I think is 10% ethanol 91 octane fuel right now (only thing available), struggling to get a decent read on afr since my widebands only reference 14.7 stoich and not 14.13 for 10% ethanol.
Thanks for any pointers you can give me!
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 04-03-2013, 05:49 AM   #2
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Change your WB to Lambda mode and 1.0 is stoich regardless of fuel. Fuel AFR/ Fuel Stoich = Lambda.
Your PE will be .80 lambda or so.
Learning to tune in Lambda is of great benefit for alternative fuels with different stoich values than gasoline.
You need to log your pulls and reduce the timing in the Spark advance vs. g/cyl table above the load and rpm when you start spraying in the hi & lo octane tables.
Iam Broke is offline   Reply With Quote
Old 04-03-2013, 07:28 AM   #3
TornadoSS
WICKDSS
TornadoSS's Avatar
Thanks! I tune and data log with the AEM, I can switch it to lambda. The NOS wideband controller though, that could be a problem. It only reads in afr, 14.7, as far as I can tell. That is what the progressive controller uses for lean/rich cutoff. I will have to dig into that a little further.
Old 04-03-2013, 07:35 AM   #4
Iam Broke
PHAT B33
Iam Broke's Avatar
The LS3 & L99 PE tables in HP Tuners invert the PE, so .8 lambda PE becomes it's inverse or 1.25 in the PE tables.
I think you get the picture.
Old 04-03-2013, 01:53 PM   #5
TornadoSS
WICKDSS
TornadoSS's Avatar
Are there any other points that need addressed in the tune as far as nitrous goes besides proper afr of approx 12.8 and timing pulled? My fuel is being supplied from a dedicated fuel system.
Old 04-04-2013, 08:00 AM   #6
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Id be a little richer than that and have the PE table start getting rich about 300-500 RPMs before the shot hits.
Phil
www.TampaTuning.com
Tampa Tuning is offline   Reply With Quote
Old 04-04-2013, 11:35 AM   #7
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Pull timing as needed, the fuel enrichment will be handled with your fuel jetting. You can fatten it up some as Phil metioned, because there will be a lean spike when it hits, completely normal.
Rhino79 is offline   Reply With Quote
Old 04-04-2013, 02:12 PM   #8
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: '15 STI, EB Expy,'10 2SS/RS M6, KB1
11.5 - 11.7 afr while spraying
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot coated LTs, JRE SCT Tune, CAI, Scoop, Rx Catch Can, Gates heater hose relocation, Remote clutch & auto brake res, Metco loop, Momentum Tunnel Brace, TSW Nurb 18" 555 & 555R, Pfadt trailing arms & toe rods, Autometer wideband, Fesler Pillar Pod, LED strips (int), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17 @ 112.6 stock
Badbubba is offline   Reply With Quote
Old 04-04-2013, 02:26 PM   #9
TornadoSS
WICKDSS
TornadoSS's Avatar
That's my target! Thanks for all the tips!
