Cold Air Inductions
Old 04-03-2013, 05:00 AM   #1
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/2012 SS
CEL 3 codes
Just got my car back friday from getting tuned and only drove it a few times, on the way to work I hit a spot that was clear of traffic so I got on it and it sputtered alittle look down and the cel is on. Pulled the codes and got
P0108
P1153
U0401
Did a search but so much came up and Im not to sure what would cause it anyway.. Can anyone help me out with what I need to do to fix these..
2012InfernoSS is offline   Reply With Quote
Old 04-03-2013, 05:28 AM   #2
2012InfernoSS
If it helps my mods are ecs kit kooks l/t's with kooks off road pipes and ported tb
Old 04-03-2013, 12:09 PM   #3
Kelly@PCMofNC
Drives: 2010 RS/SS
Did the same place that tuned it install the parts also? Sounds like it needs to go back to them to see what's going on. The 1153 is common with headers and should be addressed in the tune. The 0108 is a MAP sensor code, is the wiring damaged anywhere? That needs to be looked at too.
Did you mean U0104 on that code? The U codes are typically communication codes (between different modules) that report if there is an error somewhere - but this shouldn't be reporting anyway (I'm looking at a stock file for a 2012 and it's a non reporting code).
Were all these codes current or stored as history?
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
Old 04-03-2013, 02:38 PM   #4
2012InfernoSS
It had no cel when I got it back so I think all of the codes are current, I installed everything myself then had it towed to get it tuned
Just took a look and none of the wires look damaged, map sensor hasent been touched so I dont know why id be having a problem with it unless it went out.. the cars only has 8000 miles on it
Old 04-03-2013, 03:34 PM   #5
2012InfernoSS
Called my tuner and hes going to check it out tomorrow
Old 04-03-2013, 04:20 PM   #6
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
Who tuned it?
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 04-03-2013, 04:45 PM   #7
2012InfernoSS
Lethal performance, they said bring it in tomorrow they will get it fixed no cost
