Solo Performance
Old 04-04-2013, 08:50 AM   #15
MA2010SS
Drives: 2010 Camaro SS
Originally Posted by The Stig View Post
Be careful how far you drive before retuning the speedo, because your odometer is off too.
Very true, roughly 12% difference from 3.45 to 3.91 so there should be a 12% difference in mileage. 1000 miles read on the odometer will roughly be 880 miles real time driving until the correction is made in the tune.
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 04-04-2013, 09:41 AM   #16
Cuda7050
Cuda7050's Avatar
Drives: 2012 SS LS3
Please let us know when the 1LE factory tune/speedometer is approved for the SS.
Cuda7050 is offline   Reply With Quote
Old 04-04-2013, 05:34 PM   #17
octane
octane's Avatar
Drives: 2010 black lingenfelter
How much did that rear end cost?
[/SIGPIC]600 hp lingenfelter TVS 2300 package pedders springs adjustable struts sways all bushings brake hose kit cold air fuel pump boost twindisc clutch 1400hp axles 3.70 gear borla cat back badging coil covers floor mats lpe pedals 20"forgelines nitto,s, idealg master, clutch res,,lethal racing cam package with oil pump pushrods timing chain ,meth kit ,zl1 pump ,kooks 1 7/8 high flow Kats , ridetech rear coilovers ,air fuel gauge, fuel pressure gauge , shift light ,way cool awsome set up love it!
octane is offline   Reply With Quote
Old 04-04-2013, 05:49 PM   #18
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Installed 1900.00 Supposed to be a beefier rear end. It did look bigger than my stock.
Like it so far but still breaking it in. Second now feels like it has all the power first had. No more coming out of a turn and hitting the gas and going slow. Traction control lights all over the place not even flooring it. After tonight the rear end would of had 6 heat cycles with two overnight. Also has close to 120 miles on the gears so this weekend should be able to romp on her.
Scott@Bjorn3D is offline   Reply With Quote
Old 04-04-2013, 06:25 PM   #19
MA2010SS
It's identical to the stock SS rear, no difference in size, only gear ratio is different and not sure if they added the extra clutch to that differential. Every now and then the stock SS rear would just spin one tire due to the clutch pack being loose. People added 1 additional clutch to solve that problem.
Looks like time for you to give that rear some hell now
Old 04-04-2013, 10:04 PM   #20
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
Originally Posted by Scott@Bjorn3D View Post
No this is not from the dealer, the 1LE transmission is different part than the SS transmission and the Calc's for each part has to meet EPA approval. That Calc is being tested now. Believe me it is not my dealers fault all. If you go to a normal dealer they can only load programming GM gives them and that programming is kept in a database for each VIN. Since I want to keep my drivetrain warranty that is why I will wait for the Calc. That is why also I bought the entire rear end from the dealer for a 5 year 100,000 mile warranty to not be voided.
Basically the part we bought will be up coming upgrades from GM, if you remember the 1LE announcement they said that older SS's can be upgraded to 1LE. We got approval to get the part and keep they warranty but no one new that Tach did not have the Calc yet.
I just wanted to know what would be off and that is why I posted. I have since found gear calculators on the net so I know what I go at what speeds now. None of this was posted to pick on my dealer or GM so please do not spin it like that.
And as far as calling dealer BS, well the dealer does not even want a dime from me for the work or the rear end until the Calc comes out and is installed on my car. I call that a good dealer in my book.
I see your point now. So, your saying that the dealer has to enter the VIN to access the calibration files in the data base, and then can only access the cal files associated with that VIN? I was not aware of the vehicle calibrations being linked to the VIN like that. Good information, thanks.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 04-04-2013, 11:09 PM   #21
Scott@Bjorn3D
No problem, this is why if something breaks in the drivetrain they have the dealer pull the ECM data, TCM data and BCM data to see if they where modified or flashed more times than the VIN's database say things should of been. That is how they can tell if a car has been tuned and warranty goes bye bye.
Old 04-04-2013, 11:30 PM   #22
Atti2de
Móderator
Atti2de's Avatar
Drives: 2SS/RS
Download a speedometer for iPhone or andriod and you will see your real speed on your phone.
And am I the only one who laughed at your post header? "New rear end in but"
I'm not the one with the Atti2de problem it's everyone else that has a problem with my Atti2de!
Atti2de is offline   Reply With Quote
Old 04-05-2013, 07:27 AM   #23
mdub76
mdub76's Avatar
Drives: 2010 2ss/RS IOM GFX M6
I used android app. You are dead on. +5@40, +8 @65.
mdub76 is offline   Reply With Quote
Old 04-05-2013, 07:56 AM   #24
Scott@Bjorn3D
They are going to take on 125 miles for every 1000 the odometer says when we go in for the Calc. That will be added to extend my 36 month, 36K mile warranty. I will be way over 36K before during my 2nd year as my car is used for all my IT onsite trips.
Old 04-05-2013, 08:05 AM   #25
Tyler360
Tyler360's Avatar
Drives: 2011 Camaro 2SS/RS
Subscribed. I intend to do the 3.91 upgrade eventually too so let us know when that update is available
Tyler360 is offline   Reply With Quote
Old 04-07-2013, 11:34 AM   #26
Briand069
Drives: 1997/1969 Camaro's
Well my new 1LE rear end has been installed in my car. Only one problem, GM does not have the calibrations yet for the normal SS TR6060 for the speedometer. Should be out in about 3 months or so. So how many miles over or under am I at 35MPH and 65MPH?
Also my tach would still be the same right, so I know if I am redlining my engine?
How did you or the dealer find out about the calibration and warranty stuff? I want to do this upgrade as well but don't want a custom tune if I can help it.
1969 Camaro LT1 4L60E
2010 Camaro 2SS/RS 6spd
Briand069 is offline   Reply With Quote
Old 04-07-2013, 01:46 PM   #27
Scott@Bjorn3D
The part and Calc should be out in 2-3 months. As soon as it is out I will let folks know. All the parts needed to make a SS a 1LE are going to be released for a normal SS. I am probably going to do sways and struts down the road.
Old 04-16-2013, 09:36 AM   #28
Briand069
So, did you also change out the axels and hubs or just have the diff installed? Trying to figure out is the SS axles can stay or do they need to be changed also.
