HeadlightArmor
Old 04-03-2013, 04:38 PM   #1
smarbrit
Drives: 2012 Camaro 2SS/RS IOM
Brakes & Rotors
I just got the call from my dealer that they will be machining my rotors and replacing some parts under warranty. Parts are coming out of the US so will be another week or so before repairs are done.
I did ask about replacing the rotors but was told GM won't replace them.
Apparently GM will do this 1 time only up to 39,000 kms, if it happens again, I get to replace the rotors. Fair enough as it is related to driving habits.....They also suggested if I do brake hard and have to stop for a period (like at a light), use the ebrake. Not trying to be jerky or anything, they were just offering suggestions.
smarbrit is offline   Reply With Quote
Old 04-03-2013, 05:40 PM   #2
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Once they turn those rotors time is not your friend.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 04-03-2013, 06:13 PM   #3
slededorilllia
slededorillia
slededorilllia's Avatar
Drives: 2011 camaro 2ss convertible
so, what is the deal with the recall or service bulletin on the squeaking brakes.....just got the car out and noticed the brakes seem to squeal even after driving it for a bit.....the pads still have lots of meat on em too.....any help thanks...
slededorilllia is online now   Reply With Quote
Old 04-03-2013, 06:41 PM   #4
smarbrit
Explain??
Old 04-03-2013, 07:05 PM   #5
NFRNOSS
NFRNOSS's Avatar
Drives: 2010 Camaro 2SS/RS LS3 IOM
I've had my car in for squeaky breaks several times. They all tell me the same thing.
These are performance brakes, and they glaze up, and will then squeak at light breaking...
NFRNOSS is offline   Reply With Quote
Old 04-03-2013, 07:08 PM   #6
Merc
In The Circle
Merc's Avatar
I fail to see why using your e-brake at a light would save your brakes. BTW it's now called a parking assist brake.
Old 04-03-2013, 07:08 PM   #7
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
The breaks squeak period lol don't think I know a camaro owner that has a quiet car.
GM will replace the rotors but only after they turn them first. BS I think but h well.
CHMSC is offline   Reply With Quote
Old 04-03-2013, 07:10 PM   #8
Merc
In The Circle
Merc's Avatar
Correct. You should try Hawk HP Plus pads, great on the road course suck on the street.
Old 04-03-2013, 08:10 PM   #9
NFRNOSS
NFRNOSS's Avatar
Yeah, I'll probably change to hawks when I need new break pads...
Old 04-03-2013, 08:30 PM   #10
Merc
In The Circle
Merc's Avatar
This time when I did the DBA rotor change I bought Hawk HP's for the street and HP Plus for the road course. So far the HP's are quiet.
Old 04-03-2013, 08:43 PM   #11
smarbrit
I have 17,500 kms on my car, not too keen about replacing the brakes already.
Mine squeak when cold, doesn't bother me....
Old 04-03-2013, 09:09 PM   #12
Merc
In The Circle
Merc's Avatar
I did the rotor up-grade cause I like track days on the road course and I beat the hell out of the stock rotors.
Old 04-03-2013, 09:16 PM   #13
smarbrit
Apparently I do too.... no tracks for me tho
Old 04-03-2013, 10:24 PM   #14
Cap'n Pete
Cap'n Pete's Avatar
Drives: '02 Z28
Not sure about the specific issue(s) with the squeaky brake issue on these, but just a couple opinions on brakes in general:
- I had the original set of rotors from my '02 turned after ~60k (they had a pretty good warp in them), and continued to run them for SEVERAL track days (I mean ... A LOT of track days) and aside from developing the typical "spider cracking" (faint, surface cracking) they held up for a long time afterwards.
- any "performance" pad compound will squeak under typical street use. I've had good luck running ceramic pads for street use ... they do "work" on the track, but just don't have the same level of bite as typical pads, esp. track compounds. So unless you plan on tracking your car? (assuming most people are concerned about street driving) then I'd suggest trying a ceramic pad compound ......... I highly, highly doubt that the problem is with the rotors!?!?!
Current car:
2002 Camaro Z28 - LS1/T56 - Black
Previous cars:
2006 Corvette Z06 - LS7 - LeMans Blue
2010 Corvette - LS3/MN6 - Black
www.time-attack.ca
Cap'n Pete is offline   Reply With Quote
