sjm autoprod
Old 04-03-2013, 11:26 PM   #15
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
Originally Posted by Merc View Post
This time when I did the DBA rotor change I bought Hawk HP's for the street and HP Plus for the road course. So far the HP's are quiet.
I have the HP's on the stock rotors Brian and mine are quiet as well.
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 04-04-2013, 12:18 AM   #16
Merc
In The Circle
Merc's Avatar
Bryan
Different story if I the HP Plus on, they squeak like crazy but they bite hard on the road course.
Old 04-04-2013, 02:10 AM   #17
dragon22
dragon22's Avatar
Drives: 2010 Camaro 2SS/RS SIM
Originally Posted by smarbrit View Post
I just got the call from my dealer that they will be machining my rotors and replacing some parts under warranty. Parts are coming out of the US so will be another week or so before repairs are done.
I did ask about replacing the rotors but was told GM won't replace them.
Apparently GM will do this 1 time only up to 39,000 kms, if it happens again, I get to replace the rotors. Fair enough as it is related to driving habits.....They also suggested if I do brake hard and have to stop for a period (like at a light), use the ebrake. Not trying to be jerky or anything, they were just offering suggestions.
What they mean by this is if you're doing a lot of hard braking and have to sit at a light for an extended time, use the park brake to hold the car there instead of the pedal to prevent warping the rotors.
It was the same principle on the old drum brakes on the rear. The worse thing in the world for people to do was a lot of hard braking, then park the car and put the e-brake on as it would warp the drums.
I would give it a try. Can't hurt.
2010 2SS/RS - 6M Silver Ice Metallic
ARH LT Headers with MBRP 3" catback exhaust, Cold Air Inductions CAI, ZL1 inspired splitter, ZL1 Grille, Rear Fascia blackout, Gill decals, Aftermarket Hurst Short Throw shifter, Tune by Jannetty Racing.
dragon22 is offline   Reply With Quote
Old 04-04-2013, 02:12 AM   #18
dragon22
dragon22's Avatar
Explain??
When they machine/turn rotors, they take off a certain amount of material to make the rotors "true" again. No shop is going to take off too much material and put you back out on the road again with inadequate brakes. That's just a lawsuit waiting to happen. I've resurfaced rotors on my own vehicles over the years and had good luck with it. I've done it on lots of customer's cars over the years and had very few issues with it as well. (Unless, of course, they drive like they're on a road course). LOL
You shouldn't run into having to replace the brakes yet. Get as much as you can out of them. You paid for them. LOL
Old 04-04-2013, 03:09 PM   #19
Wild Thing
Royal Cdn. Navy (Retired)
Wild Thing's Avatar
Drives: 2010 Camaro 2SSRS
ebrake
I fail to see why using your e-brake at a light would save your brakes. BTW it's now called a parking assist brake.
The E brake is seperate from the regular brakes they do not touch the roter, thus when after hard braking useing the E Brake instead of regular brakes just to hold the car from rolling will keep the pads off the rotor letting them cool equally instead of staying hot under the pads when stopped after hard braking which may or may not cause distortion.
Wild Thing is offline   Reply With Quote
Old 04-04-2013, 03:20 PM   #20
smarbrit
Drives: 2012 Camaro 2SS/RS IOM
Originally Posted by Wild Thing View Post
The E brake is seperate from the regular brakes it does not touch the roter, thus when after hard braking useing the E Brake instead of regular brakes just to hold the car from rolling will keep the pads off the rotor letting them cool equally instead of staying hot under the pads when stopped after hard braking which may or may not cause distortion.
This is exactly the reason they gave me for using the e/parking brake.
I am surprised to have this issue though as I don't drive this car hard and I don't brake any harder than I ever have in any other vehicle I've owned. I've never had to slam on my brakes for any reason but sometimes there's just not enough time to gear down. Even coming down from highway speeds, the car slows enough on its own without needing the brakes or just limited use. I know my ABS has kicked in a few times, but that's due to snow/ice, not speed.
smarbrit is offline   Reply With Quote
Old 04-04-2013, 03:38 PM   #21
Meltdownaverted
I sell Camaro's
Drives: traded 11 2SS RS SGM for 13 SS 1LE
We had I guy here that had to have his turned as well, GM won't replace them unless they've been turned once. He doesn't drive his car hard either its been a year and hes had no issues
Meltdownaverted is offline   Reply With Quote
Old 04-04-2013, 08:41 PM   #22
Cap'n Pete
Cap'n Pete's Avatar
Drives: '02 Z28
Once the rotors have heated/cooled a bunch of times and warped, that warp is "set". Turn the surface, get them true again, and they likely won't warp any further. At least, that was my experience .
Current car:
2017 Cruze Hatchback - oh yeah!
Previous cars:
2006 Z06 - LeMans Blue
2010 Corvette - LS3/MN6 - Black
2002 Camaro Z28 - LS1/T56 - Black
www.time-attack.ca
Cap'n Pete is offline   Reply With Quote
Old 05-09-2013, 09:16 PM   #23
smarbrit
Finally got to test the brakes this past weekend after they were machined and they still vibrate when touched at highway speeds. I've called the dealer and it's going back in on Tuesday.
Old 05-14-2013, 12:24 PM   #24
smarbrit
Dropped the car off this morning and the service fellow tried telling me GM will only machine the brakes 1 time. I completely understand that, however they'd better be fixed properly the first time and after only a month and first time getting it to highway speeds, still having them vibrate tells me they didn't complete the job 100%. Apparently they only did the front rotors, not the back...
Old 05-15-2013, 06:01 PM   #25
Robd
Robs SS
Robd's Avatar
Drives: 2011 camaro ss synergy
I'd definitely stick to my guns till its fixed right or it will be one of those 1000 dollar bill non warranty repairs later if you don't feel like they're getting it call gm Canada and make sure your concerns are documented that's my opinion as I've found sometimes just cause u express concern to service advisor it doesn't mean it's noted in your file
[COLOR=lime]my kinda going green POWER 605 RWHP powered by maggie chrome tsv 2300 supercharger,ar long tube headers high flow cats b and b exhaust ,roto fab intake ,lingenfelter cam , upgraded sc reservoir ,Comp cams
performance valve springs, Comp cams Titanium retainers,Heavy duty valve locks,MSD ignition wires, Kool Sox heat resistant heat sleeves , Larger fuel injectors, high flow fuel rails,American racing rims ,hurst short throw shifter,led footwell and grille lighting,pfadt suspension upgrades
Robd is offline   Reply With Quote
Old 05-15-2013, 09:40 PM   #26
smarbrit
Well.....I got the car back yesterday and it wasn't the brakes. It was an issue caused by hungover boys not paying attention when changing the winters out......fixed now. Tested the brakes and they are all good.
Old 05-15-2013, 09:51 PM   #27
NFRNOSS
NFRNOSS's Avatar
Drives: 2010 Camaro 2SS/RS LS3 IOM
What did they forget to do?!?!?
NFRNOSS is offline   Reply With Quote
Old 05-15-2013, 11:37 PM   #28
smarbrit
Remove the spacers. In their defense though, nothing on any of my paper work from purchasing the winters or having them put on noted the spacers were there and I wasn't told when I picked it up after the install.
There were clips that came off with each tire and I questioned if there were spacers (just learning about them in the forum) but they couldn't see them.....
