Old 04-03-2013, 08:46 PM   #1
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1
Carbon Fiber hood insert
I have a 2013 zl1 and I can see dimples in my clear inserts. Had the dealer replace it but the dimples on the new insert seems worse then the old ones. From the back of the insert in about an inch and half and in from the sides about an inch. Anybody else notice this?
owhite3003 is offline   Reply With Quote
Old 04-03-2013, 08:51 PM   #2
Flea
Drives: Camaro ZL1
I haven't noticed it, and I don't even want to look. If I do notice it, it will drive me crazy.
Flea is offline   Reply With Quote
Old 04-03-2013, 08:52 PM   #3
16floz470ml
16floz470ml's Avatar
Drives: 2012 ZL1 GLJ MG9 WBP RTQ
With RPO B92
The appearance concerns with “Raw” carbon fiber (non painted) may include, but are not limited to, uneven material color or weaves, wrinkles or “waves” in the fabric, light or dark fish scale type spots, loose threads, fabric seams or joints.
Types of “Carbon Fiber” Vehicle Applications Most automotive “carbon fiber” trim used on vehicles is a cosmetic applique that gives the look carbon fiber but is not structural Composite Carbon Fiber. This material has a consistent weave and color appearance.
Structural Composite Carbon Fiber generally has visible fabric inconsistencies and a yellow or milky appearance unless it is sanded, clear coated and polished to give the panel a more finished look.
Real Composite Carbon Fiber Appearance Every Composite Carbon Fiber panel or part has a unique appearance based on the color and clarity of the resin, the pattern and layout of the fabric and the shape of the part. The weave of the material, the color variation of the fabric in the weave and the layout of the layers varies slightly from part to part and no two pieces are identical or “perfect” in appearance. This is similar to the way a natural wood or a hand made piece of ceramic or pottery varies from piece to piece.
In the case of the ZL1 hood insert, the part is inspected, wet sanded to smooth the surface, coated with a UV (ultra violet) protective clear coat and polished to a high gloss finish.
Addressing Customer Concerns
The following images display some acceptable non repairable Composite Carbon Fiber appearance traits:
Light and dark spots, sometimes described as “Fish Scales.”
Wrinkles or “waves” in the fabric weave.
Uneven material color, color shift.
Repair Procedures With RPO B92 If there are minor scuffs or abrasions on the UV protective clear coat surface, hand polishing with a mild polish such as 3M™ Finesse-It™ II Glaze, Part #059283 is recommended. No machine polishing is recommended.
If there are small dimples or impressions around the perimeter of the insert, loosen the threaded fasteners (retaining nuts) and Re-Tighten to 4 Y (35 lb in).
Repair Procedures Without RPO B92 Camaro ZL1 vehicles may also be equipped with a hood air extractor that is finished with a conventional paint finish. If there is a flaw in the finish on the Ashen Grey gloss painted finish, conventional polishing methods can be used to correct minor surface flaws and scuffs. If the panel is finished in a semi-gloss black, there are no recommended repair procedures for surface imperfections.
16floz470ml is offline   Reply With Quote
Old 04-03-2013, 09:09 PM   #4
owhite3003
Z-BEAST
owhite3003's Avatar
Thanks. The Carbon fiber looks good, it is the clear coat that looks dimpled. I might just have to live with it.
Old 04-03-2013, 09:14 PM   #5
HDRDTD
Is there any chance those are the locations where mounting studs are located and someone just slightly overtorqued them during the install??
Old 04-03-2013, 09:17 PM   #6
camaro2lt
camaro2lt's Avatar
if anyone has pics of the underside of the hood were all the bolts go can you post them thanks
Old 04-03-2013, 09:20 PM   #7
Russo
Unofficial Glass Tech
Russo's Avatar
Drives: 2014 Ford F150 FX2
Send a message via Yahoo to Russo
the thing is that it's supposed to be uneven... imagine spraying a clear coat on sand...
Russo is offline   Reply With Quote
Old 04-03-2013, 09:31 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
try some pictures. "dimples" are kind of like say your car is making a wonka wonka noise. a picture is worth 1,000 words.
IF it is fish eye's in the clear it is poor paint prep and could be sanded and recleared possibly.
Without "seeing" it hard to comment.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 04-03-2013, 09:41 PM   #9
owhite3003
Z-BEAST
owhite3003's Avatar
The dealer said it wasn't where the mounting stud was. The first one you could see and feel a crack. This one, I just noticed the divot and thought I would ask.
Old 04-03-2013, 09:43 PM   #10
razorz28
razorz28's Avatar
Drives: 2017 Jeep Rubicon, 2016 Z06
That is not how it is sprayed.
razorz28 is offline   Reply With Quote
Old 04-03-2013, 10:00 PM   #11
01pewterz28
Camaro Junkie
01pewterz28's Avatar
That sounds like the problem he has too much pressure on the studs this can be fixed losen the bolts holding the insert and let the vehicle bak out in the sun the dimples should go away.
**FIFTY HBM 2SS VERT**
Old 04-04-2013, 10:36 AM   #12
Russo
Russo's Avatar
i know how carbon fiber is made.. don't go full retard on me please
Old 04-04-2013, 11:06 AM   #13
ZL1 TIBS
ZL1 TIBS's Avatar
Drives: 1968 Camaro, 2012 ZL1
I think I know what you are talking about. My ZL-1 has the same thing. I don't let it bother me, but I may try to loosen the mounting stud if it appears that is where it is dimpled.
Alan Tibbetts
Aston, PA
1968 Chevrolet Camaro LS-1/T56 transplant
2012 CRT 6 SP ZL-1
ZL1 TIBS is offline   Reply With Quote
Old 04-04-2013, 11:09 AM   #14
razorz28
razorz28's Avatar
Well if you are comparing it to sand you have no idea how CF is made.
carbon fiber, hood, zl1
