JUICEDMOTORSPORTS
Old 04-04-2013, 05:40 PM   #1
KY1LE
KY1LE's Avatar
Drives: 2013 Camaro 1LE 2SS,RS,NPP
NPP Exhaust Issue
I just got home with my 1LE and noticed that the exhaust valve on the NPP is staying open all the time. Is this normal? I thought it would shut after start up and then be shut until over 3,000 RPM.
KY1LE is offline   Reply With Quote
Old 04-04-2013, 05:50 PM   #2
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
at idle/startup and below 2k it is open.
at 3k or higher it is also open.
so only if you hold the rpms in that middle range will it be closed
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 04-04-2013, 05:53 PM   #3
DuskSS
DuskSS's Avatar
PS just yank the fuse and be done with it till you get heavily modded
sounds great going through the loud side.
only after I cammed and did my exhaust did I bother putting a mild to wild in to keep the cam at bay while chugging around.
530/520 SAE
Old 04-04-2013, 06:06 PM   #4
KY1LE
KY1LE's Avatar
Great! Thanks, I thought I had an issue already!
Old 07-08-2014, 05:20 PM   #5
2014CamaroRS
Drives: summit White 2014 Rally Sport
Smile
is there a way to keep the chamber open in the exhaust it sounds a lot better!!!!!!
2014CamaroRS is offline   Reply With Quote
Old 07-09-2014, 12:34 AM   #6
raptor5244
Drives: 2016 Camaro 2SS - Mosaic Black
Yes, search for NPP fuse pull. With the fuse pulled the flap stays open all the time.
raptor5244 is offline   Reply With Quote
Old 07-09-2014, 05:09 AM   #7
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
Not a 1LE but this is how mine is programmed. You can hear it close about 10 sec after cold start and hear it open at 3000.
Consensus is, by definition, a lack of leadership.
Indydriver is offline   Reply With Quote
Old 07-09-2014, 07:51 AM   #8
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
That's odd, it should stay open until you reach 2000rpms unless under heavy throttle.
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 07-09-2014, 09:20 AM   #9
Indydriver
Closes backing down the driveway (which is a good thing).
Old 07-09-2014, 10:51 AM   #10
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
There is a fuse panel in the trunk, mounted on the right side inner quarter. Remove the trunk liner, pull fuse F8 (ext flap). Reassemble and there you go.
HOJO is offline   Reply With Quote
