HURST
Old 04-04-2013, 08:14 PM   #1
Bosse'sBoss
Bosse'sBoss's Avatar
Drives: '14 Corvette Stingray Z51 A6 transm
Question Who has 305/30 R19 tires all around on their 1LE
Who has the 305/30/ZR19 on all 4 wheels in their 1LE (like on Pedders Camaro or in the new Z28)?. Any improvement at the track?. Do you had to lower it? How wide are your wheels?. Do you had to adjust your speedometer? Post some pictures.
Bosse'sBoss is offline   Reply With Quote
Old 04-04-2013, 08:24 PM   #2
BloodRain
Drives: 1LE
I don't know of anyone who has that setup yet!
BloodRain is offline   Reply With Quote
Old 04-04-2013, 08:29 PM   #3
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
who would give up the sick ass/expensive 20's that come with the 1LE and go to 19's?
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 04-04-2013, 08:41 PM   #4
Bosse'sBoss
For the track. Wider tires & wheels = Better handling. Like on the Z28 and Pedders
Old 04-04-2013, 08:43 PM   #5
Synner
Drives: not stock
You would need 10.5" width, yes there would be a weight and gearing benefit, and you only have to lower it if you want but the tire change will already drop it about 3/4" and also increase fender gap. If you want it accurate you would need to adjust the speedo.
Old 04-04-2013, 09:05 PM   #6
SumWhite1LE
King of All
SumWhite1LE's Avatar
Drives: 2014 Summit White Z28 #275
Wider tires = more friction on the track. Thats why our 1LE's come with the same size tires on the front and rear. Just the rear tires are stretched onto the wider rear wheels.
SumWhite1LE is offline   Reply With Quote
Old 04-04-2013, 09:11 PM   #7
Synner
Drives: not stock
No it was done for neutral handling with a square setup.
Old 04-04-2013, 10:05 PM   #8
SumWhite1LE
King of All
That too.
Old 04-04-2013, 10:54 PM   #9
JJKJ
JJKJ's Avatar
Drives: 2013 2SS/RS 1LE
Someone who wants a true track tire. There are a few options in 20's for street/track tire hybrids but the true track tires don't come in sizes larger than 19's (without being ultra-expensive).
John
13 VR 2SS/RS 1LE (sold)
01 Z28 M6 HT
JJKJ is offline   Reply With Quote
Old 04-05-2013, 05:15 AM   #10
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
Just keep in mind that a lot of very smart folks put together a package that has been deemed "the best handling Camaro ever". The current tire and wheel combo is part of that package. It is your car, and I am not saying it can not be improved upon, but bigger is not always better!
gajagfan is offline   Reply With Quote
