sjm autoprod
Old 04-05-2013, 02:56 AM   #1
MY CA.ZL1
MY CA.ZL1's Avatar
Drives: 2012 ZL1 #698
jannetty 75rwhp package issue
I was wondering if anyone had this issue.when i slowly step on the gas the car runs amazing.when i floor it the car acts like it is not getting enough fuel.and cutting out.i also installed a rx catch can.was wondering were to look first?Name:  20130404_173140.jpg
MY CA.ZL1 is offline   Reply With Quote
Old 04-05-2013, 02:59 AM   #2
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
Definitely email and or call Ted, he stands by all his products and should straighten that right out!
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 04-05-2013, 07:17 AM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
sounds like a tune issue. I know this kit is touted as a "no tune" mod but the high limit the ECM is seeing on the boost tables is probably getting past whatever limit is present. It makes sense that it would happen when you quickly apply the throttle as the boost will spike at first. Jannetty will fix it with his tune no problem.
'17 ZL1 A10 Mosaic Black PDR/Nav
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-05-2013, 10:43 AM   #4
islander033
SLOBRA1
islander033's Avatar
Drives: GT500/Cruze/DMax/Cobra
Are your nannies on or off when this happens?
2010 GT500 Best ET=10.10 - Best Trap=143.59mph
2003 Turbo Cobra Best ET=8.32 - Best Trap=164.51mph
islander033 is offline   Reply With Quote
Old 04-05-2013, 11:50 AM   #5
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 13 ZL1, 15 Scat Pack,& 15 Silverado
I agree 100%... Get a tune
2013 M6 ZL1.. Mods- Roto-Fab CF Intake, Ported and Polish LS7 TB and Snout, 2.55" Upper Pulley, 100mm Idler Pulley, Solid Isolator, Afco Heat Exchanger with fans, ID850 fuel injectors, SW 2" LT Headers With High Flow Cats, and CMS 91 Octane tune.. 579.8rwhp and 537.4rwtq
TripleBlkZL1 is offline   Reply With Quote
Old 04-05-2013, 04:15 PM   #6
MY CA.ZL1
MY CA.ZL1's Avatar
Thank u for telling me to turn off nannies.made a big difference.
Old 04-05-2013, 04:36 PM   #7
MY CA.ZL1
MY CA.ZL1's Avatar
Ted so got back to me today and spent alot of time going over what to check.item by item.i didnot have nannies turned off . which was brought up by a member and the chance I could of broke the ajuster for the boost on s.c.when I did the work.he is not only very good at what he does but very detailed on explaining what to do.thanks to everyone for your input.
Old 04-05-2013, 06:07 PM   #8
GAZL1
Drives: 2013 ZL1
Glad to hear you guys figured it out!
Since I'm also looking at Ted's 75hp "no tune" package, I just want to be sure your problem was just the nannies being on...correct? If not, please elaborate.
GAZL1 is offline   Reply With Quote
Old 04-05-2013, 07:30 PM   #9
MY CA.ZL1
MY CA.ZL1's Avatar
First Ted was very detailed as he was before i got this package.Yes it was just the nannies being on.using the torco is somewhat of a pain but without tuning and 91 fuel in ca.i have no choise.what is nice is that if i do tune jannetty does free tuning and will load to my laptop.i load to my sct.and download to my car.if i add a mod like headers new tune and again free.this is a great package.
Old 04-05-2013, 08:59 PM   #10
Stephen12ZL1
Drives: '17 ZL1 A10
sounds great...glad it was so simple.
Old 04-07-2013, 12:18 AM   #11
Lombardi
Lombardi's Avatar
Drives: 2010 ABM Camaro 1LT
Janettys is a great place. I have the opportunity to live a block away from them. Glad you solved you problem tho!
Sent from my iPad using Tapatalk HD
Lombardi is offline   Reply With Quote
Old 04-07-2013, 03:12 AM   #12
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Sweet, keep an eye out for my ride, will be down there Monday and Tuesday!!
Old 04-07-2013, 12:45 PM   #13
Lombardi
Lombardi's Avatar
Sweet ill have to take a drive by before work. EVERY TIME I go by there there's always a fifth gen outside. I love it.
Old 04-08-2013, 08:16 PM   #14
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
It's the "Burst Knock" kicking in. I was having the same problem and tuned it out. The PCM is seeing a rapid change in airflow(cylinder air delta) and pulls timing as a result. This rapid change(delta) in airflow is way increased because of the pulley. If you were to scan the car you would see a negative spike in the timing when you step on it. I discovered this early on as soon as I put the pulley on mine. Doesn't have anything to do with the nannies, (unless you lose traction). Unfortunately only solution is a tune. Or just ease into the throttle so it doesn't happen.
Bryan 695 SAE RWHP 2012 ZL1 9.55 pulley custom cam and Kooks headers, 2002 Z06 447 RWHP, 2006 Trailblazer SS, 1995 S/C Vortech Trans Am 570 RWHP(for sale)
ZO6 Bryan is offline   Reply With Quote
