Rick@Livernois
Old 04-05-2013, 09:21 AM   #1
amerimuscle
Drives: 2011 Camaro 1SS
cam or blower ? which order
I want to do the l99 to ls3 conversion and will eventually get a blower. Logically, which order should i do em in ?
amerimuscle is offline   Reply With Quote
Old 04-05-2013, 09:42 AM   #2
Rick@MidwayPerformance
Drives: 2010 & 2012 Camaro SS
Cam first since the heads have to come off, blower second. Just easier and less work. Make sure that you get a good middle of the road cam that will work N/A and with a supercharger.
Rick@MidwayPerformance is offline   Reply With Quote
Old 04-05-2013, 09:49 AM   #3
amerimuscle
Jre rough idle blower cam?
Old 04-05-2013, 09:54 AM   #4
rdblan2
Drives: 2SS RS
Blower friendly cam first.
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
rdblan2 is offline   Reply With Quote
Old 04-05-2013, 09:59 AM   #5
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
You're kind of in one of those positions where you should do it all at one time. If you do your conversion first with cam, even though a N/A cam will work with a blower, you won't get optimal performance as you would with a blower cam, and vice versa. I would do the blower first. If you do the cam second, you can also bang out that conversion at the same time.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 04-05-2013, 10:29 AM   #6
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Do the cam and LS3 conversion first.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 04-05-2013, 10:33 AM   #7
BlkSlvrdo129
Drives: 2008 Silverado
Same time and save yourself doing a lot of the same disassembly twice. But if you had to split the two jobs then cam first.
BlkSlvrdo129 is offline   Reply With Quote
Old 04-05-2013, 12:30 PM   #8
jfayardiii
Drives: 2011 Silver 2SS/RS L99
amerimuscle, I'm right ahead of you, I went cam first but its not what would be defined as a blower cam. Through research and input from the members here, if i had to do it again and KNEW that I was going to get a SC, then I would have opted for a cam that would give me the 100% benefit of the blower once installed.
That being said, dont think I'm swapping cams!
2011 2SS/RS L99
10.76@130.5 1.67 60'
LG headers and exhaust, 3200 Yank, EPS Cam, D1SC Procharger, all work performed by Blanchard Performance
jfayardiii is offline   Reply With Quote
Old 04-05-2013, 01:10 PM   #9
carlos@redline-motorsport
Drives: 98 Z28
With a free flowing exhaust a blower cam looks very similar to an NA cam.
carlos@redline-motorsport is offline   Reply With Quote
Old 04-05-2013, 01:55 PM   #10
Jessika
Drives: Anything Blown
Once a supercharger is installed, it can be removed from the engine for further mods VERY simply. Easier than a manifold.
I am a big fan of doing things in stages to prevent issues with troubleshooting if needed. It also increases the fun factor, imo.
Jessika is offline   Reply With Quote
Old 04-05-2013, 02:01 PM   #11
amerimuscle
Hilarious that on something that seems quite objective there are 100% conflicting reports. I literally got nothing out of the thread lol im sure you all have quite a bit of knowledge but...im still at square one?
Old 04-05-2013, 02:07 PM   #12
yotaman96
yotaman96's Avatar
I disagree with that. Supercharger is much bulkier, heavier, and has the intercooler coolant hoses running to it. Much easier to remove the stock manifold.
Old 04-05-2013, 02:09 PM   #13
amerimuscle
Looks like its jannetty time lol
Old 04-05-2013, 02:20 PM   #14
grocerygetter
instigator
grocerygetter's Avatar
blower first, then gears, then cam and converter.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
