JDP Motorsports
Old 04-05-2013, 02:29 PM   #15
StephenS_84
Drives: 2011 2SS/RS
I went blower then cam. I'm not sure what way is the right way, but thats what I did. It's up to you, save up and do it all at once.
StephenS_84 is offline   Reply With Quote
Old 04-05-2013, 02:47 PM   #16
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
There is only one fact here that's not opinionated. If you're having a shop do the work, you're paying twice if you do the mods separate instead of all at the same time when it comes to labor. Albeit different amounts of labor for each mod but still the jobs overlap in that regard. Unless you plan to run a centri . Then, it doesn't really matter as much. In either case the cam specs going forward become the decision point. There are other options, such as adding headers and full exhaust system. I've seen some L99s get 40 WHP out of a complete system with a good tune. That will work with whatever you do going forward even on an engine swap you're still good . Just a thought.
UNRIVALED SS is offline   Reply With Quote
Old 04-05-2013, 03:25 PM   #17
amerimuscle
Drives: 2011 Camaro 1SS
That makes sense. I have LTHs alrdy, and it would most likely be a centri
amerimuscle is offline   Reply With Quote
Old 04-05-2013, 04:09 PM   #18
old motorhead
Drives: Maggie blown LS3 vette
You'll need two tunes no matter which you do first. Get it done all at once. The change will be more drastic......the shiteatin' grin will be bigger and last a little longer that way
old motorhead is offline   Reply With Quote
Old 04-05-2013, 04:12 PM   #19
amerimuscle
well through Mr. Jannetty all tuning will be free but it seems best case scenario all at once, second place would be cam first then blower.
Old 04-05-2013, 04:44 PM   #20
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
I had the same questions as you. Except im LS3. But after i priced out both i decided on the supercharger first. More horsepower out of the box for just a little bit more money. Ted is installing it on monday. Once that is paid off ill go back to him for the long tubes, tune and rough idle cam
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 04-05-2013, 06:10 PM   #21
amerimuscle
Ok a lil turn in OP , but ive done some searching and didnt come up w much but.... D1sc or p1sc for the l99 shooting for 600+ish wheel
Old 04-05-2013, 06:16 PM   #22
BrainleSS
Working on my 2nd one!
BrainleSS's Avatar
Drives: Camaro
I just did them at the same time.
BrainleSS is offline   Reply With Quote
Old 04-05-2013, 06:41 PM   #23
UNRIVALED SS
Horsepower wise the supercharger is where it's at. You can always run more boost if you want more power. Other components will eventually limit what you can get out of it but its a stock longblock, so you'll be making reasonable power based on the limits of that component .
Old 04-05-2013, 06:48 PM   #24
RBD
RBD's Avatar
Drives: 2013 SS/RS Convertible
Originally Posted by amerimuscle View Post
Jre rough idle blower cam?
I have it and its a nice cam.
RBD is offline   Reply With Quote
Old 04-05-2013, 06:52 PM   #25
RBD
RBD's Avatar
Vortech V-3 with JRE's upgrade package and I'm at 715@ the tire with an M6. LPE dual pump
set up and ID-850s. 3.70 gears 23 mpg hwy
Old 04-05-2013, 07:15 PM   #26
amerimuscle
Thats legit, how much did that run u? Blower + upgrade ?
Old 04-06-2013, 05:38 PM   #27
RBD
RBD's Avatar
Contact JRE for the best price.....
Old 04-13-2013, 04:19 AM   #28
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
..not really objective. There is no set way to do it, and no one is right or wrong.
I did cam first for the sound improvement as well. The smirk you had going from stock to LTs ... its 100x better with a cam... and you get the power adder. It is also cheaper so it was a nice step up to work for the SC
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
