Emblempros
Old 04-05-2013, 06:33 PM   #1
coptzr
Resistance is futile
coptzr's Avatar
Drives: Anything thats fast
HELP!!! 1LE/ZL1 wheels hit in front!!
ARGH...got my black 10 spokes today. Tires are 285/35/20 Michelin Pilot's. When I installed I found they hit the frt strut, and not a little either. I didnt tighten down much and it seems the wheel hits too...Anybody elsae have the same issue?? They hit hard enough you cant turn the wheel....was I suppose to get all 4 rear's ??? hate to sound stupid....
Modifications (so far)
Edelbrock E-Force supercharger
JRE fuel system upgrade
Edelbrock CAI
VMS stage 2.5 cam kit
SLP LT's, no cats
NPP muffler's w/x-pipe
Tuned at Vector Motorsports
606 RWHP and 567 RWT
Black 1LE 10 spokes.
Hotchkis drop springs.
coptzr is offline   Reply With Quote
Old 04-05-2013, 06:45 PM   #2
slickz28
slickz28's Avatar
Drives: 2010 camaro ss/rs
try spacers
slickz28 is offline   Reply With Quote
Old 04-05-2013, 06:51 PM   #3
NinoSS
Drives: 2SS/RS CGM LS3
mine are on the way...
SOLD Vengeance stage I cam (442rwhp/412rwtq) / CAI intake w/ADM race scoop / Dynatech LT's / ATI udp / JRE tuned / Eaton Posi LPE-JRE 3.91's / L99 Corsa / Whiteline Sways & Bushings / UMI Trailing Arms & Toe Rods / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 04-05-2013, 06:55 PM   #4
coptzr
coptzr's Avatar
NinoSS, what part #'s did you order?? I know the front and rear are different but are you suppose to use 4 rear # so it clears the front?? been researching and dont see anyone else with the same issue
Edelbrock CAI
SLP LT's, no cats
Old 04-05-2013, 06:57 PM   #5
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
To confirm, did you purchase 4 rears wheels? 20x11?
Fronts are 20x 10.
Old 04-05-2013, 06:57 PM   #6
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
The fronts and rears are different. Assuming you have them on the right end of the car, I don't know why you would be having any trouble.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 04-05-2013, 06:58 PM   #7
coptzr
coptzr's Avatar
no, 2 front part #22798741 and rear #22798743
Edelbrock CAI
SLP LT's, no cats
Old 04-05-2013, 07:01 PM   #8
NinoSS
Mine are OEM's from a ZL1. Maybe your rears are on the front? There is no way a 20x10 +25 should rub on the front. The rears are a 20x11 +45, they would likely rub...
Old 04-05-2013, 07:05 PM   #9
NinoSS
The pic in the OP looks like the 285 is streched (can't really tell). The 285 might be mounted on the rear wheel and placed on the front?
Old 04-05-2013, 07:08 PM   #10
coptzr
coptzr's Avatar
Well unless they were all boxed wrong...grabbing the tape measure now.
Edelbrock CAI
SLP LT's, no cats
Old 04-05-2013, 07:09 PM   #11
NinoSS
Old 04-05-2013, 07:10 PM   #12
coptzr
coptzr's Avatar
Hard to get a god pic. Is it true the 1LE uses all 4 same wheels?? if so it may be my issue. Maybe they do that to clear the front strut??
Edelbrock CAI
SLP LT's, no cats
Old 04-05-2013, 07:13 PM   #13
NinoSS
No... The 1LE uses the same set up as the ZL1 (the specs are in my post above) but with 285's all around...
Old 04-05-2013, 07:13 PM   #14
SumWhite1LE
King of All
SumWhite1LE's Avatar
Drives: 2014 Summit White Z28 #275
The 1LE uses 20x10's in the front, and 20x11's in the rear. Same size tire all the way around. Sounds like you have the rears on the front.
SumWhite1LE is offline   Reply With Quote
