Old 04-06-2013, 05:21 PM   #1
AMCBimmer
Drives: 2002 BMW M5
Auto Cross Tires using Stock Sizes
Does anyone know of a good auto cross tire that would be better than street tires? Either I would like stock or bigger for the sizes?
AMCBimmer is offline   Reply With Quote
Old 04-06-2013, 07:21 PM   #2
Synner
Drives: not stock
Best thing you can do is pick up an extra set of rear wheels to run on the front and then get something like Nitto NT05's in 275 all around. Or get the NT555 if you need wet weather traction. You won't find much of anything thats sticky in the OEM staggered fitment.
Old 04-06-2013, 08:43 PM   #3
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
Or you need bigger rims and runNto5's 275 front 315 rears, or the Invo's
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 04-06-2013, 09:55 PM   #4
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Look in to the toyo r888 in 285/35r20 or the new bfg rivals in 285/35r20 those would be great performing tires im planning on the rivals in 285's all the way around once we finish killing these pzeros this season at autocross
But weve also got 3 sets of wheels so we have a daily set and a set of autoX wheels
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 04-06-2013, 10:09 PM   #5
Synner
Drives: not stock
Well the r888 isn't meant for stock width wheels, I wouldn't be going over 275 on a 9" since handling suffers putting a larger tire on smaller rim especially for this type of use. If he stepped up to a 10" then it would be good on a second set of wheels
